1025 Views 15 Replies Latest reply: Dec 8, 2012 4:43 AM by TEPrewitt23 RSS
Blues_man001 Just Startin' 17 posts since
Jun 18, 2007
Jul 15, 2012 2:02 PM
Hd500/Variax 500.....Please help.
I previously had an X3 Live and the Variax 500 was able to update firmware and all was well.  I just got an HD500 and got it updated through Monkey and went to hook up the Variax to it and the firmware update failed.
I received error "Flash Memory, Variax update failed.  error code 8000900C MIDI device timed out waiting for a response.  Try the update again, making sure all the cables are connected."
I am using a Windows 7 Pro PC with driver 4.2.5.4
Monkey V - 1.58
HD500 - 1.43 and 2.02 (have had installed and tried variax update)  On 1.43 now.
HD500 Edit - 2.00
Workbench 1.73 (which redirects to run monkey to update Variax).
I only had 2 USB devices plugged into the board (mouse and keyboard).  I removed all USB devices and followed the directions to reset the Variax as well as the HD500, instructions here:
http://line6.com/supportarchive/thread/55633
The HD500 reset correctly, but the Variax doesn't make the tones that "pierrehurtubise" mentioned in his post about resetting the variax.  On mine I get a High-Low-High sequence tone as I first plug the Cat cable in and pull up the tone selector knob (with pickup selector in position 2 (from bridge).
Please advise on how I can get the Variax to update in order to use it.  I removed the battery from the back and even checked the connections to the electronics on the back of the Variax.  I can't think of any reason why it won't update.  Thanks
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Aug 31, 2012 3:30 PM (in response to Blues_man001)
        Re: Hd500/Variax 500.....Please help.
        Blues_man001 wrote:
        I just want to put in here (not that anyone is reading this nor my other 2 entries) that once your Line 6 device becomes out of warranty or a legacy product - don't expect too much support from.......
        Actually, I think that is pretty much standard from electronic equipment manufacturers - not only Line 6. Of course the Variax 500 is essentially a computer; and like any computer it becomes outdated and (eventually) fails. When manufacturers move products to legacy status they stop receiving updates and eventually are no longer supported (think Power PC in the Mac world). Your Variax 500 is still supported - but not under warranty. You could get it fixed at an authorized service centre, but as Line 6 suggested you would be better off (i.e. it would be cheaper) to simply buy a working one.
        The newer series of Variax guitars (JTV) include mag pickups so it won't become a paperweight when (eventually) its electronics fail. If that happens before it becomes a legacy product then I expect Line 6 will still be supporting it very well.
        Have you considered buying a new computer - I mean Variax JTV?
            Dec 22, 2006
            Sep 3, 2012 12:36 PM (in response to Blues_man001)
            well the 500 originally came out in 2002, so i think that 10 years is not exactly setting fire to money...
            of course none of that matters and you're clearly free to move on...
            i just wanted to add that bit of info to the discussion.
            feel free to send it to me, i'll get it fixed and continue to enjoy it.
                Dec 22, 2006
                Sep 4, 2012 9:08 AM (in response to Blues_man001)
                sorry dude... you made your feelings known... noone can get you parts, so i'm not sure how else you expect to be responded to....
                if it matters remotely... i wish they had parts for the older variaxes as well as the older vetta amps... both were expensive in their day and both do not have aftermarket equivilents... i know many users who would be happy to have parts... but then they would complain that the parts are expensive... as they would be since you'd have to pay for the warehousing in the cost... at a certain point the cost of parts is more than the cost of replacement. the same is even true for the common television.
    • amx05462 Power User 3,495 posts since
      Sep 1, 2008
      Dec 6, 2012 3:02 PM (in response to Blues_man001)
      i cant  help you on that one. ive never seen the acoustic board  .  i would  guess it would be  a version of the same board  but  without  seeing it   i couldnt tell you  if it  would even fit in place.
      funny thing though i saw one  from either  an amp or pedal board that looked  similar in configuratoin to the   300 i had . but  not exactly..  keep an eye  on ebay .. ive seen   them  there  from time  to time   why someone  would part it  out though vs selling  the guitar would  make  me  suspicious.
        honestly  i think your  best bet is  if you really  feel you have to have a variax.   then  getone  off ebay  and save  the parts  from the one you have  now.
      that really  is the easiest   way to go about this..
