137 Views 3 Replies Latest reply: Jul 23, 2012 10:51 AM by EminentAndrew RSS
EminentAndrew Just Startin' 5 posts since
Jul 19, 2012
Jul 20, 2012 9:43 AM
Is this option available?
Hey Guys,
A couple things to start off : I am in ABCD Mode (FS1-4 Effects; FS5-8 Presets). My Delay is assigned to (FS1) is off in Preset A(FS5).
I wan't to Turn on my Delay (FS1) while my in preset A (FS5) Then go to Preset B (FS6) then back to Preset A(FS5) and have my delay off again.
Basicly I want my defaults to load every time I toggle between FS-5-FS8 and not have the preset change every time i leave an effect(FS1-FS4) on or off.
PLEASE HELP!
Thank you.
  • Astaroth_CY Just Startin' 112 posts since
    Aug 18, 2007
    Jul 20, 2012 9:55 AM (in response to EminentAndrew)
    Re: Is this option available?
    The behavior you say that you are looking for is what I am experiencing by default. I.e. if I turn on an effect for a patch, then switch away from it to a different patch and switch back to it, the effect will be off again as I originally saved it.
    The only way I would possibly see that you migh be experiencing the opposite (i.e. effect stays on when you go back to the patch) is if you're at the same time connected to your computer via USB and have HD Edit running, but even then I'm not sure this would happen.
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Jul 20, 2012 10:09 AM (in response to EminentAndrew)
    The behavior you're describing is how it should work. It sounds like you are probably trying to switch presets while connected to HD500 Edit.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
