58 Views 0 Replies Latest reply: Jul 22, 2012 9:52 AM by LSD-Studio RSS
LSD-Studio Just Startin' 1 posts since
May 19, 2008
KFM: complete POD mix, incl Backing, DIs, POD Presets..Giveaway
Line6 GiveAway!!
I've just Created a POD equivalent of each of the guitarsounds I used for Killfloor Mechanic's "The End Of Madness".
That is:
Rhythm Guitars (original: Earforce)
Crunch Guits (original: JMP2203)
Melody (original: 6505)
Solo (original: Soldano)
I came quite close , without any post processing, only the Earforce (or rather what was supposed to sound like Earforce) needed a little bit of post EQ, it'll sound good without any post EQ though, that one is just if you wanna get closer to the original Mix...
I used only the standard models, so even if you don't have the MetalShop AddOn you'll be able to use these presets and replicate my Sound.
Here's the POD version of the song (every single guitar was reamped through the POD XT Pro, using only the supplied presets):
http://www.youtube.com/watch?v=4OxmmvMJtY0&feature=player_embedded
you can download the zip from the link in the yt description
That folder contains:
The full POD version of the mix
All the POD presets
The Waves Q8 preset for the RH Guits Post EQ
A Screenshot of said post EQ (in case you don't have the plug)
All the DI tracks
The backing (everything but the guitars)
The lyrics
Guitar Pro tabs will be added in future updates
