596 Views 9 Replies Latest reply: Sep 16, 2012 4:55 AM by scotty_burford RSS
Emiliano78 Just Startin' 5 posts since
Jul 24, 2012
Jul 26, 2012 5:33 AM
Serious problems with a new DT25 Head - it's normal?
The mode "clean" is almost completely unusable (both assigned to channel A and channel B), polluted by a kind of annoying overdrive - not a normal tube soft-click - in the background at any level of gain.
Also for what concerns the mode "clean," with a low gain is usable only in "low volume mode" ... if you switch to the normal volume, the clean low-gain (for example 25-30%) do not feel at all ... instead os increasing the volume
is no longer heard ... and so you have to raise the gain almost to 50% to hear something!.
  • hollis1003 Iknowathingortwo 342 posts since
    Feb 6, 2007
    Topology I (the cleanest) is normally run with the Volume (not the Master) on that channel very high (100% is not uncommon) and the Drive is set very low.  This gives the absolute cleanest sound.  If you are still getting any distortion you may have a problem with your amp, cables, pedals, or guitar.
    You may also need to re-seat your power amp tubes.  With any tube amp there will be some background hiss.  If the tubes moved at some point during shipment you may get additional noise that is unintended.
  • Krontab Just Startin' 201 posts since
    Mar 15, 2006
    If you got it at a local store have them exchange it for another one. My first one was a dud as well. If you bought it online consider opening a support ticket with Line 6. If it is just the tubes you judge whether or not $40 some odd dollars should be spent repairing a new piece of equipment. Shipping does all sorts of things to sensitive electronics. These are built well but not for bumping around (note lack of metal corners).
  • scotty_burford Just Startin' 89 posts since
    Sep 14, 2009
    I have just replaced the original tubes and had it biased by a tech. Big difference!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
