1263 Views 20 Replies Latest reply: Dec 8, 2012 10:23 AM by ciadude2 RSS
samuelito2011 Just Startin' 105 posts since
Nov 14, 2011
Jul 27, 2012 11:57 AM
Question about pod hd500 with analog pedals!!!
Hello Friends
I have a big question, does anyone know how the pod hd500 react adding analog pedals such as : chorus, noisegate, ODs, etc?
Im about to but the pod hd500 with a pedaltrain pro but i also want to combine analog pedals. Im afraid the analog pedals will be a waster for buying it, thats why im looking for answer for those who is combining them.
if anyone know a video, a track or sound! please post the link and i will listen it!
Im planning to combine just analog pedals with pod hd500 amps and then direct to Mixer! thats my idea!
  • Currently Being Moderated
    Jul 27, 2012 4:12 PM (in response to samuelito2011)
    Re: Question about pod hd500 with analog pedals!!!
    I wanted to do this too and have found a good sound. Although  I use the 4 cable method or 4CM with an amp, you can probably just use the od's, distortions, compressors before the Pod, then in your amp patch insert an effects loop and put your mod type boxes in the loop, then run out from that to your mixer.  put the effect loop patch just before the amp sim. then try after to what sounds better
    I use the above method but with 4CM and the pedals all sound great.  be sure to set your levels proper in the mixer as to not overdrive your mixer channel which would sund like crap unless it's a fine old tube mixer or something
    If that does not sound so good then try running it without the loop patch.  I've also had some luck running everything straight into the mixer.
    I'm sure there is a more technically appropriate way to do it and that someone will pipe up to say so, but in the mean time I'd give this a shot.  seems to be the most straight forward method.  be sure to set your output in the POD to direct or studio
    yo
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Jul 27, 2012 4:28 PM (in response to samuelito2011)
    I have a bunch of pedals I use...Mostly with my HD400...I also have an HD Bean and I use them with it also, but only recording as that setup is less practical live...
    Right now I have a BOSS BCB-60 with mostly old Boss pedals in it...I have a Strymon OB.1 compressor...My prized pedal is my Boss DM-3 analog delay...All of them work great with the HD Pods...
    • vidaljuanes Just Startin' 104 posts since
      May 16, 2010
      Sure you can improve.
      how hard is a professional setting.
      analyzes the configuarción TC G-System Electrinic
    • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
      Jan 24, 2007
      The modelled amps respond the same way that the real amps would with the same pedal infront of them.  It's really as simple as that.  If you hit these amp models with a hotter input from a boost, they'll start to overdrive up just like the real amp would.  If you put a distorted tone, modulated tone or wah'ed tone into them, they'll amplify that tone and react to it in the same way as the real amp that's being modelled.  Line 6 have put an enormous amount of effort into the authenticity of their amp modelling and it shows when you do things like put pedals into the modelled effects chain.
      Cheers,
      Crusty
  • scotty_burford Just Startin' 89 posts since
    Sep 14, 2009
    I use several different pedals in my setup and they sound fantastic with the POD. I have a Hotcake Overdrive, Eric Johnson Fuzz Face, Vox Satchurator, BBE Boosta and a Deja Uni-Vibe in conjunction with the POD.
    In the past few months ( I admit I struggled to get the tones I had hoped for initially) I have had many people comment on my tone and say how awesome it sounds. Always a good thing. Didn't always get that with my last setup!
    May 16, 2010
    Holas, estoy a las puertas de comprarme un amplificador Egnater Tourmaster , y quiero saber como es la configuración en utilizando el software, con el metodo de los 4 cables.
    estoy claro que debo enviar las distorsiones al imput del amplificador, eso significa enviarlas desde el SEN del HD500, pero los reverb y delay como se mostrarian en el software?
    Hellos, I'm on the verge of buying a Egnater Tourmaster amp, and I want to know what the configuration using the software, with the 4-wire method.
    I am clear that I send the amplifier distortions imput, that means sent from the SEN of the HD500, but the reverb and delay as displayed in the software?
    gracias por sus comentarios.
    • fede17_dream Just Startin' 27 posts since
      Jan 5, 2008
      Dec 8, 2012 4:55 AM (in response to vidaljuanes)
      Hola! Las reverbs y delays tendrían que estar despues del bloque "FXLoop" del pod, para ubicarlos despues del pre del amplificador.
      Saludos!
        May 16, 2010
        ok, gracias Fede17_dream, entonces el setting es:
        1) cable 1 : de Input guitarra a IN del HD
        2) cable 2: del SEN del HD al Input del Amplificador ( y equi configuro el FXLoop con un compresor por ejemplo y luego un overdrive ) y tambien podria colocar (SEN del HD al Input del Bloody Mary y del Ouput del Bloody al Imput del Amplificador)
        3) Cable 3: Return del HD al SEN del Amplificador
        4) Cable 4: del Out del HD a Return del Amplificador y el delay + reverb que configuro en el software se iria por aqui?
        desde ya gracias.
        ok, thanks Fede17_dream, then the setting is:
        1) Cable 1: Input IN HD guitar
        2) Cable 2: SEN of HD to Amplifier Input (and configure the equipment FXLoop with a compressor for example, and then an overdrive) and could also put (SEN of HD to the Bloddy Input Ouput of Mary and the Imput of Blody Amplifier)
        3) Cable 3: Return of the SEN HD Amplifier
        4) Cable 4: Out of the HD to Amplifier Return delay + reverb and configure the software that would go over here?
        from already thank you.
          Jan 5, 2008
          Dec 8, 2012 7:24 AM (in response to vidaljuanes)
          No se si entendi bien la pregunta...
          Vos queres conectar el Bloody Mary con el pod y el amplificador con el metodo de los 4 cables?
          La cadena podria ser asi:
          1) Cable 1 Guitarra >>> HD in >>> Efectos del pod qe quieras antes del pre del ampli (distorsion, etc) >>> FXLoop(del pod) >>>
          2)Cable 2  HD SEND (envío) >>> AMP Input
          3 )Cable 3: AMP SEND >>> HD Return >>> Efectos que quieras despues del pre del amplificador (Delays, Reverbs, etc, los que configuras "por software").
          4)Cable 4: HD Main Out (L o R) >>> AMP Return.
          El Bloody Mary lo podes poner entre la guitarra y el pod, o entre el SEND del pod y el Input del AMP. Fijate como te gusta mas. Va a depender de que simulacion uses del pod. Tenes que ordenar las ganancias. Yo pondria de menor ganancia a mayor. O sea, si usas el Screamer del pod, el Bloody Mary lo pondría entre el SEND del Pod y el Input del AMP. Pero es cuestion de probar...
          Espero que te sirva la respuesta, saludos!
            May 16, 2010
            OK, esa era mi duda, te pasaste.
            al cambiar mi configuración de entrar a un power y ahora conectarme a un cabezal a tubos los bajos son muy hermosos, el bass del bloody supera en mucho al bass que te entrega el HD.
            saludos.
            OK, that was my question, you spent.
            to change my settings to get to power and connect to a head now to the low tubes are very beautiful, the bass of bloody far exceeds delivers bass you HD.
            greetings.
  • ciadude2 Just Startin' 46 posts since
    Jan 27, 2011
    Dec 8, 2012 10:23 AM (in response to samuelito2011)
    I've only used overdrive/distortion pedals in front of it but they've worked pretty well.
    The Boss Metalzone sounds exactly like the one built in the HD500 I have, but with a few more tone tweaking options. Other than that though, spot on.
    So if you have pedals you want to use with the HD500 go for it.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
