192 Views 2 Replies Latest reply: Oct 20, 2012 6:19 AM by hurghanico RSS
thealexkelley Just Startin' 1 posts since
Jul 26, 2012
Jul 28, 2012 12:46 AM
HD500 not working with usb
hey guys I'm having issues here with my hd500, in test mode it connects fine to my macbook pro running on os x 10.8 but once I plug it in regularly it starts to freak out and just keeps restarting with the line 6 startup screen. I've tried hitting left on the d-pad as I saw it would be a global reset from other threads but it just isnt working for me. I feel like I've tried everything from reinstalling all the hardware and drivers to  trying different outlets and nothing seems to work. when i hold down view and look at setup page 1 it says USB FW:V0.00 so maybe it's the usb firmware? if so how could i fix it? thanks in advance!
  • MarianoBL Just Startin' 2 posts since
    Apr 29, 2012
    Oct 20, 2012 12:12 AM (in response to thealexkelley)
    Re: HD500 not working with usb
    Tengo un POD HD
    Me pasa igual en un iMAC. Actualizo a version USB FW:v1.1, y sale lo mismo en el display. Una vez lo apague y lo vuelva a enceder es cuando el display indica:USB FW:0.00
    Todo parece trabajar bien. El pequeño problema es que muy de tarde en tarde se apaga y se vuelve a reiniciar al instante.
    En espera de tus comentarios
    Mariano
    I have one POD HD
    I like going on an iMac. Upgrade to USB FW version: v1.1, and comes out the same in the display. Once you turn it off and return to main SW is when the display shows: USB FW: 0.00
    Everything seems to work well. The problem is that very little now and then shuts down and then restarts instantly.
    Waiting for your comments,
    Mariano
  • hurghanico Just Startin' 399 posts since
    Jan 28, 2007
    Oct 20, 2012 6:19 AM (in response to thealexkelley)
    I dont think your problem is due to the usb firmware ..
    if I turn on the HD500 and I go into the system setup, I read: USB FW: V0.00
    if I connect the HD500 to my PC and go back into the system setup, I read: USB FW: V1.01
    if I disconnect the HD500 from my PC, turn it off and on, and I go into the system setup, I read again: USB FW: V0.00
    so I suppose that is an information that is detected only when you create a USB connection
    what are you plug-in to your HD500?
