326 Views 12 Replies Latest reply: Oct 12, 2012 8:25 PM by wetredbox RSS
Jul 29, 2012 2:46 PM
4cm with tube amp, some preamps have more volume mkaing switching difficult
So I have a Randall MTS modular amp.  I'm using two of it's preamps along with effects only patches  as well as a Hiwatt (pod) patch, bypassing the amps preamps.  I've tweaked all this to allow me to switch between the amp's own Plexi and Deluxe channels, and then choosing the Hiwatt on the Pod with that patches effects.  works pretty well although I could mess with levels till I'm dead to make it better.
This setup is awesome so far.  The problem arises when I go to say a Pod AC30 patch.  the volume available does not match the Hiwatt patch or the amps preamps.
I have the mixer level all the way up on the left side, right is muted, I also have a studio EQ in there to bring up the volume but this adds gain and flavor which I'd like to eliminate, just getting the intended Pod preamps sounds through the amp.  I can max out the gain on the Pod preamp and I'll have volume but it's all gain.  not ideal for me
The Hiwatt amp works well because the gain is pretty well maxed and the nature of a Hiwatt is that it';s not high gain, more like a boost, the others so far do not work the same way...  Is this just the physical nature of the modeled amp? a 100 watt Hiwatt vs. a 30 watt AC30?  seems like there should be a global volume.  I have followed the 4CM notes up here and like I said, it works well with the Hiwatt model
what am i missing here?
input appreciated
