415 Views 7 Replies Latest reply: Dec 1, 2012 8:06 PM by Jerry259 RSS
Jerry259 Just Startin' 8 posts since
Apr 21, 2012
Jul 29, 2012 7:42 PM
Hybrid guitar, Aura Spectrum, HD500, dual tones & viability of it all!
Based on weeks of reading, I think that this will work but I would like to know 100% that it will.
I want to run both the piezo and magnetic pickups of a hybrid guitar through the HD500 as tone 1 & 2 respectively.
Tone 1 - MAGNETIC would at least have compression, eq, amp & cab, reverb, delay, as well as wah and some mod effects once in a while (trem, chorus, flange, etc).
Tone 2 - PIEZO would have compression, eq, reverb and delay. Sometimes I may run an amp & cab for some interesting tones (whish may cause DSP limit errors).
Alternatively for Tone 2, I may get a Fishman Aura Spectrum DI which would simplify DSP useage. The Aura has 3 band eq, compression and 3 notch filters for feedback.
I would mix Tone 1 & 2 in the post area as I would actually prefer sending one stereo mixed signal to the soundman. I want to control how much electric or acoustic tones get heard based on the song I am playing. I could also then add some delays that would apply equally to both tones at times. I could also make full use of the onboard looper.
I will always run this through a PA system. I do not own a guitar amp and will not be buying one. The signal will be XLR left & right out to the PA, then back to me via monitors.
QUESTIONS:
1) Will this work??
2) Will I run into DSP limit errors??
3) If I never run amp & cab on the piezo signal, should I be free of DSP limit errors??
4) Can I have some patches setup to run both piezo & magnetic AND some patches setup to only run the magnetic signal as dual tones?? I am refering to the input settings. Can I change input settings for some patches or is it one way for every patch??
THANKS!
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    • Will it work?:  basically yes but with limitations as per below.
    • Will you run into DSP Limits?  I think that with an amp model on both paths and use of Reverb and delay then the answer is probably 'yes'.
    • With just one amp you should get away with it but frankly the risk is still fairly high if you use a 'greedy' combination of effects.  Doubling up on Reverb and Delay is probably the biggest issue.
    • Input settings you can choose to either set for all patches or to set on a patch-by-patch basis.  You would achieve what you want with the latter.
    Not 100% that I understand your mixing setup but you will save DSP if you can share Delay/Reverb and or modulation across both channels.  This can be achieved by putting the FX post-mixer..
    Piezo with amp models?  Not entirely sure why you would want to.  You can probably do better with EQ or the Vintage pre-amp on that channel.
    Bearing in mind that you can set some patches to be Piezo and others to use the Mag pickup:  do you need to blend the two signals at all?  Just thinking out loud ....
        Jun 27, 43450
        Impressive tone on that vid!   Surprisingly realistic.  Of course there is always the Variax .....
          • meambobbo Iknowathingortwo 1,702 posts since
            Dec 13, 2007
            You don't need a Variax.  What you are saying can be easily acheived.
            Set Input 1 to Guitar and run the magnetics into the Pod's Guitar input.
            Set Input 2 to Mic and run an XLR from your Piezo to the Pod's Mic input.
            Do not put ANY effects in front of the channel split.
            In Channel A, put the amp/cab you want and any effects you want to only hit the magnetics.
            In Channel B, put your compressor and EQ.
            Pan both channels dead center in the mixer and level their volumes relative to each other so that the tone is as dirty as you ever want it.
            Place effects common to both signal behind the mixer (delay, reverb).
            Put a Volume effect right before the mixer in Channel A.  Assign its volume parameter to your expression pedal with min 0%, max 100%.
            Now when you have the exp pedal in heel position, you have 100% acoustic signal.  With the exp pedal in the toe position, you have the dirty mix you wanted.
            If adding the dirty tone into the acoustic tone makes the volume too high, try setting another Volume effect at the end of Channel A and controlling it via the same EXP pedal, but set min to 100% and max to ~80%.  This will decrease some acoustic volume as you add in the dirty magnetic tone.
            Volume effects are VERY cheap DSP-wise.  Reverbs are not.  If you need a reverb but cannot fit one, try using a Delay with a short time instead.  It sounds fine especially if you have a longer delay on top of it.
            With both channels having amp+cab, you're going to get close to hitting the DSP limit if you use any reverb.  Otherwise, you should barely be ok.
          • Rewolf48 Just Startin' 133 posts since
            Aug 9, 2010
            The Tyler Variax Guitars (JTV) can output both Mags and Variax Models at the same time through the DVI connection.  You can set path A to be "Variax" and Path B to be "Variax Mags" on the HD500 and have both sounding at the same time.  There are several demos of this around.
            I have one patch that I use for Jethro Tull's "Aqualung" which has a heavily distorted electric and then switches to an Acoustic with a capo at the thrid fret - I play it with my JTV using the Bridge humbucker into a "line 6 electric" for the distorted electric and the variax through just eq, compressor and reverb; the HD500 patch sets the variax to the correct Acoustic setting (factory) and does the transposing for the capo when I select the patch, and I use the expression pedal to switch between the two by varying the volume on each path.
            The only thing I have to remember to do at the start of the song is to have the expression pedal in the correct place, the variax pickup switch in the humbucker position (JTV-69) and to then switch to the patch.
