Aug 1, 2012 7:23 AM
[ASK] problem about sound of POD HD300
Like (0)
hello all, please help i have a problem with my pod hd300, the produced sound was not maximal. this happen after i play it about 10 minute,
and then the sound become muddy/sounds more bass, the sound like covered by something/like sound clipping, so the produced sound become lower & little humming.
anyone have a solution about that problem.
thnxz before.
This question will help understanding:
Has this state become permanent now, or can you always start normal, and this happens always after a while?
Have you changed something recently / before this happend: Firmware update, connecting to your PC, moved the expression pedal, etc...?
If your device is o.k., some have strange behavior after firmware upddate, when they forget to do the factory reset and pedal calibration subsequently.
thanks for the response..
1. Has this state become permanent now, or can you always start normal, and this happens always after a while?
all of this happen after i play for couple of minute, so for the first time i turn ON POD HD300, it's work well (sound was normal), but after a while the sound getting worst.
2. Have you changed something recently / before this happend: Firmware update, connecting to your PC, moved the expression pedal, etc...?
yes, i have tried all the firmware to the latest update now (v2.0.1), but still happens.
any other solution, please help i was confused with this problem ![]()
thanks
You have answered the first 2 points.
But you also say:
"yes, i have tried all the firmware to the latest update now (v2.0.1), but still happens."
-> So what about my 3rd point? Have you done the factory reset and pedal calibration, or have you forgotten?
while I have not had these issues myself, i have heard others having similar ones and usually a factory reset and re-upgrade of firmware takes care of the problem.
