128 Views 4 Replies Latest reply: Aug 15, 2012 4:56 PM by cesar77758 RSS
cesar77758 Just Startin' 3 posts since
Aug 4, 2012
Aug 4, 2012 9:01 AM
Uber Metal shuting down
Hi, my Uber Metal was working nice, then one day , while using it the light got red red red and it shut down
i tried using the battery but nothing, when connected to the amp it sends some kind of noise like turning on and
off ( tum tum tum tum), would it be the module or the body that got broken? is this common or any solutions for this??
Thanks!
César
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    Aug 5, 2012 3:54 AM (in response to cesar77758)
    Re: Uber Metal shuting down
    Hard to say.  Have you tried reseating the module in the dock?
    If reseating doesn't work, then something is broken (electronics don't last forever.)
    Is there a music store nearby where you can try your module with one of their docks, or vice-versa?
    I don't use the Uber Metal, but I do use Echo Park.  I went out and purchased a spare on the used market so that I can narrow down problems like this, as well as have a spare in a pinch.
        Mar 12, 2007
        Aug 7, 2012 4:36 AM (in response to cesar77758)
        What power supply are you using?
        Use a hex wrench to remove the set screw and pop the module out.  After that make sure the contacts are clean and put it back.  You also might want to try your friends module in your dock, and vice versa to narrow down where the problem is.
