225 Views 11 Replies Latest reply: Aug 27, 2012 6:56 AM by Triryche RSS
Ant_222 Just Startin' 6 posts since
Aug 11, 2012
Aug 11, 2012 3:08 PM
How to monitor during recording?
Hello all,
I am using SoundForge 7.0 to record from mikes via UX2, and can't find a way to set up the system (Windows mixer, SoundForge, and UX2) to be able to hear the sound being input from the mikes in the headphones. I can hear the recording only when I play it back. Can you help me?
Anton
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Aug 13, 2012 6:32 AM (in response to Ant_222)
    Re: How to monitor during recording?
    Plug your headphones into the UX2.
    Feb 20, 2007
    Aug 13, 2012 7:07 AM (in response to Ant_222)
    And the UX is selected as your sound device?
    Feb 20, 2007
    Aug 20, 2012 6:40 AM (in response to Ant_222)
    Are you launching POD Farm standalone (not the plug-in within Sound Forge)?
    In Sound Forge for record and playback does it indicate ASIO?
    I would contact Line6 directly via a support ticket or call:
    http://line6.com/support/tickets/add.html
    Line 6 - North America
    Line 6, Inc.
    26580  Agoura Road
    Calabasas, CA 91302-1921
    Main Phone#: (818) 575-3600
    Main Fax#: (818) 575-3601
    Customer Service hours are 8am - 5pm M-F Pacific Time
    Press option 3 for Customer Service
    Our busiest hours are from 11am to 2 pm.
    Line 6 - Europe
    Line 6, Inc.
    The POD
    Clifton House
    Butler's Leap
    Rugby, Warwickshire
    United Kingdom, CV21 3RQ
    Telefone: +44 (0) 1788 566 566
    Fax: +44 (0) 1788 566 529
    Technical Support: +44 (0) 1788 566 555, Mon-Thurs 9am – 5pm GMT and Fri 9am – 4pm GMT
      • Mavril Just Startin' 8 posts since
        Jan 18, 2007
        Aug 20, 2012 8:43 AM (in response to Ant_222)
        I've never used Soundforge 7.0 but I have used 8 and 10. You are correct that when you set up your audio device that you must perform a self test and determine your latency etc... when you arm for record, a separate window pops up and should display the faux LED bars. If you can see these levels then you know you are able to direct monitor (which is what you want to do). As you mentioned, there should be a check box in the window at the bottom  left to feed that signal back to your output bus (whether that is your monitors or headphones). By default this box is unchecked but should be there to check.
        If you do not see this box, check your soundcard setup in Soundforge, it doesn't matter if the card is ASIO or any other type of card, your hardware should be able to reroute the direct signal back to the output bus. I remember a card I had back in the 90s that i had to physically route with an external cable but that was several generations of technology ago and I would be shocked if the UX2 abondoned this feature.
        Anyone owner's confirm that direct monitoring is possible with the UX2?
        Also can you please list the other hardware you are using? i.e laptop, pc, version of windows etc... it will help to funnel down the possibilities.
    Feb 20, 2007
    Aug 27, 2012 6:56 AM (in response to Ant_222)
    You would need to launch POD Farm to monitor the inputs.
    Or you can try turning on "Monitoring" in SF (make be called something different) but it will likely introduce latency.
    The recording will not have latency, just the monitoring.
