430 Views 8 Replies Latest reply: Aug 19, 2012 3:56 PM by geppert RSS
Serph Just Startin' 9 posts since
Jun 21, 2012
Aug 18, 2012 7:18 PM
HD500, mackie HR824 and QSC K12
Well i'm looking for something that amplifies the pod hd500 without affecting it's sound or anything so i found 2 speakers or like they call them monitor speakers, (mackie HR 824) and (QSC K12)
Mackie HR824:
-They told me that these are good and they do not affect pod hd500 and that i should get a pair of these, well i don't know my self.
QSC K12:
i didn't find anything about this product only the fact that it's a PA speaker (i think) and that it can be used for live shows and small avenues but if they are good do i have to buy a pair too.
I hope you discuss both products and give more details about them, because i dont want to buy tube amps.
and can these be connected to the computer and help me record my stuff?
    • BigBob369 Just Startin' 58 posts since
      Nov 9, 2007
      Aug 19, 2012 12:06 AM (in response to Serph)
      Re: HD500, mackie HR824 and QSC K12
      These are PA speakers with built in amps, except the last one which is a self amplified studio monitor (With a 5" speaker).  They will all amplify your POD with very little coloration, especially as compared to guitar amps.
      I have a 400watt  Alto 12" PA speaker and a Roland KC300 keyboard amp for amplifying my POD HD Bean.  They each sound great for this purpose and only cost me $250 and $350 respectively.
      You will be able to amplify your HD500 with low coloration using any of these products, yours or mine. All but the Rokit will be more than ample for stage work too.
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Aug 19, 2012 5:06 AM (in response to Serph)
    You  don't need a pair of powered speakers unless you want to run stereo effects.  You can quite happily run a single speaker.  If you are recording then you can choose to go stereo or mono.  If Stereo then you need a pair.  For live the same choices apply but Mono is definitely simpler.
    You can use any of these speakers for recording but the  QSC is  more for live sound and may not be optimal as studio speakers.  The Rokits and Mackies are designed for studio use and are less suited for live sound.
    Look also at the QSC10 which should be just fine for guitar (less so bass).
    Are you planning to use these speakers for live or just for home/recording?  If just home then you are probably best off with the Mackies or Rokits IMHO.
  • BMoe Just Startin' 62 posts since
    Feb 7, 2010
    Aug 19, 2012 5:25 AM (in response to Serph)
    Serph,
    I own the HR824s, they sound great with HD500,  As Jim stated, the HR's are near monitor speakers (3-5 foot range) and made to use in a studio (home, project etc...)
    And they are great to use in a recording atmosphere also.
      • geppert Just Startin' 188 posts since
        Nov 8, 2010
        Aug 19, 2012 3:56 PM (in response to Serph)
        I also have the Mackie HR824 MKII speakers on Primacoustic pads. I run the PODHD500 through them all the time since I like having the sound up in front at ear level AND in stereo, especially for chorusing and delays. The Mackies straddle the computer display monitor spread about 3' apart and I sit about 2.5' in front directly in the middle. These Mackies do a fine job of it (I also use them for mixing music). One cavet however. The Mackies are full range studio quality nearfield speakers and obviously sound different than guitar amps (I use a DT25 head/cab) so I find that my saved preset tones need to be tweeked specifically for one playback system or the other. I run from the 1/4" outputs (L/R) into an 8 channel line mixer (so I can have my Mac Audio, Protools, Midi Modules, etc. etc. plugged in simulateously and relatively balanced between each other into the Mackies). The Pod goes XLR (Line 6 Link) to the DT25. This way I have either guitar amp or Mackies on demand at all times. I usually Spdif into the 003 for recording or you can also go XLR out (L/R) into the 003 (or whatever interface you are using). There are a few ways to do it. The POD500 is very versatile for output configurations.
        I use AKG K701 headphones as another monitoring option. Killer headphones.
