247 Views 7 Replies Latest reply: Feb 7, 2013 5:47 AM by fflbrgst RSS
Mattbass Just Startin' 3 posts since
Aug 24, 2012
Aug 24, 2012 8:07 PM
Shortboard Mk11 won't calibrate?
My shortboard Mk2 won't calibrate.It will keep reading "CHECK VALUE 0" , It dosen't wan't to read "CHECK VALUE 127".
I have been through the re- calibration procedeure a dozen times, watched the video, re-installed the latest flash....
I have tried it connected to my POD and my commputer via USB. All the other buttons function perfectly,
I can even switch the "volume" light to the "wah" light with the pedal.
Any thoughts????
Thanks.
  • fflbrgst Power User 1,292 posts since
    Mar 6, 2011
    Aug 28, 2012 8:28 AM (in response to Mattbass)
    Re: Shortboard Mk11 won't calibrate?
    Have you tried a different CAT5 cable?
        Mar 6, 2011
        Aug 30, 2012 5:57 AM (in response to Mattbass)
        You definitely need to disconnect the USB connection to calibrate.  You haven't mentioned if you have a Spider amp, but as you need to connect the CAT5 cable to do the calibration, an amp is needed (I don't think PODs have this connector).
        Here is the proccedure:
        FBV Shortboard Mk. II:  (Note: Before performing the calibration routine, please disconnect any expansion expression pedals IE: EX-1)
        1)  Hold the D button while connecting the CAT-5 cable on the FBV. The display will read “CALIBRATE PEDAL” until the D button is released, at which point it will read “1 PEDAL TOE”.
        2) Press and hold the internal pedal toe-switch until the LCD changes to “2 PEDAL MIN”.  This should occur instantly.
        3) Set the heel to (minimum) position, press the D button.  The LCD will change to “3 LCD MAX”.
        4) Set the toe position (maximum) and press the D button.  The LCD will change to “CHECK VALUE 127”.
        5) Move the pedal and verify that the value reaches 0 in the minimum position and 127 in the maximum position.
        6) Press D to exit
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
