Aug 30, 2012 8:30 PM
Is it possible to get three voice harmony using POD HD400?
Like (0)
Hi all,
I want to get three voiced harmony using my HD400 like Joe satriani used in the song WHY. http://www.youtube.com/watch?v=x6D-KwY-r08 Is it possible? if yes, please help me ![]()
Thank You,
I cannot watch the video for licenseing reasons, but genrally you can generate a 3 harmony tone as follows (just reading the manual, I don't have the device before me at the moment).
- There is a smart hamony effect. You just play a single note, and it will automatically gerenate harmonies as selected. You can choose between different scales from ionic to locrian.
- HD500 users can also use the pitch/glide effect as 2 path (A+B). On path A you set his effect with your desired pitch and the mix level at e.g. 50%. For path B you do the same with a different pitch. The result is 3 tones at the same time.
The pitch can be controlled e.g. over the expression pedal. So you can have set path A to 1st and 5th, and control the 3rd harmony over path B with the expression pedal.
HD300/400 are reserved for a 2 pathed patch, so the pitch/glide effect will only generate a 2 tone harmony.
... is the bottom line. Sorry ![]()
Thanks for the reply mazuwa. The only way now to get three voice harmony is to record the harmonizing parts and play along. ![]()
