Sep 4, 2012 5:06 PM
Bypass EQ frequencies
Like (0)
I was hoping that in the EQ modules processing we could bypass each frequecy for A-B listening! I allways have too put the frequecy at 0 dB to do so, and sometimes i forgot the gain value that it have before, or even if i remember all the values it's not practical reseting the gain and give it all again each by each to a A-B listning...my 2 cents...maybe it's possible and i haven´t realized that! Thankx
On any deep tweak dsp modules, you have an "virtual on / off switch" on the lower left corner of the screen.
You can use that to bypass the effect for quick A/B comparation between processed and unprocessed signal. Or, in your case, "EQed" and not "EQed" signal.
Hope it helps.
Anton i don't see anything on lef corner... mayby you are talking about the right corner related to the on/off virtual switch! the blue (on) and gray (off). But this will bypass all the EQ module!! What I want is , let's say you are using a EQ6, is the bypass of only one or more parametric band not all the bands! thank you for the reply! Cheers!
Yah, It's the right corner! My mistake LOL
I don't see how you could bypass just an EQ freq... I use the global EQ bypass often. And not just on the M20d. Never felt the need to bypass just one freq.
to a A-B test is very usefull! Like the eqs from waves plugins for example!
