171 Views 4 Replies Latest reply: Mar 13, 2013 8:21 AM by silverhead RSS
rucademoura Just Startin' 30 posts since
Apr 12, 2012
Sep 4, 2012 7:16 PM
Main outs and L6 LINK
Can I use L6 Link and main outs at the same time? If so, can control the outputs volume separate, like using L6LINK to Front of house, and mains out to side field?
  • line6jonb Line 6 Support 47 posts since
    Jun 11, 2012
    Sep 18, 2012 4:19 PM (in response to rucademoura)
    Re: Main outs and L6 LINK
    Yes you can use both L6 Link and the main outputs at the same time.  However, you cannot control their volumes separately.  Turning up the master volume will turn up the volume of both the L6 Link and Main Outs.  If you would want to control your volumes separately, you could use 2 monitor outs and control the monitor send masters for separate volume control.  However, in that case, each monitor will have its own master volume level and will need to be change individually.
    • kmachman Just Startin' 29 posts since
      Jan 26, 2013
      Mar 12, 2013 8:24 PM (in response to line6jonb)
      Is this the case even if you make a stereo pair of monitors?
      • linesixy Just Startin' 6 posts since
        Jul 8, 2007
        Mar 13, 2013 2:25 AM (in response to kmachman)
        I may be wrong... as I don't own the mixer or speakers at the moment.  However, could you use the mixer to control the 'master volume... and then use the volume control on the back of the Line 6 speakers to adjust the balance between the main outs and the what's coming through the Line 6 speakers?  (I assume there's a volume control on the back of the Line 6 speakers).
        • silverhead Expert Line 6 User 9,592 posts since
          Apr 1, 2009
          Mar 13, 2013 8:21 AM (in response to linesixy)
          Yes, there is a volume control on the back of the Line 6 speakers. But it is a global control and affects all inputs. So both the L6 LINK and the normal inputs to the speaker are controlled simultaneously.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
