963 Views 20 Replies Latest reply: Apr 17, 2013 8:58 PM by meambobbo RSS
meambobbo Iknowathingortwo 1,702 posts since
Dec 13, 2007
Apr 17, 2013 9:00 PM
dual cab setlist/research
For those who have followed my work with the Pod HD, you know that I have often used "dual cabs" in my patches.  For those who don't, see here to catch up: http://foobazaar.com/podhd/toneGuide/cabsMics#dualCab - basically I'm using the same amp in a dual amp patch but varying the cab/mic used in each channel.  I combine a "bright cab" with a "dark cab" to get a consistent, high-quality frequency response from the uber-lows to ultra-highs.
A big part of dialing in these tones revolves around one cab/mic being out-of-phase with the other.  Previously, I used two crude methods to work-around this issue: either find combinations that seemed to be in-phase, or try adding a neutral EQ or two to one Channel only to see if it improved the tone.  Today, I present you a solid set of research data that more accurately demonstrates and rectifies the issue.
But first, here is a small sample of my research applied to a HD 500 setlist.  Notice the tone is consistent and rich throughout the entire frequency spectrum.  I cannot get close to this quality of tone with a single amp/cab.  If you can, I'd like to see your patch.
http://foobazaar.com/podhd/toneGuide/dualCabs.h5s
This is just the tip of the iceberg.  I plan to complete this setlist with other cabs serving as the "bright cab" other than the Tread V-30 and 57 on axis.  I also want to make multiple setlists for each of the high gain amps.  I also want to add the Marshall T75 cab.  I want everyone who enjoys high gain to hear what the Pod HD is truly capable of.
The naming convention for each patch is "2_X_Ym_Zn" where 2 means dual cab setlist, X means amp used, Y means cabinet in Channel A, m means mic in Channel A, Z means cabinet in Channel B, and n means mic in Channel B.  For instance, the first patch is "2_R_R-_R/" - this means dual cab setlist, Rectifier amp, Rectifier cab with 57 on axis mic in Channel A, Rectifier cab with 57 off axis mic in Channel B.  Below lists all possibilities for the legend:
Amps
  J - JCM-800
  R - Rectifier
  U - Uberschall
  F - Fireball
Cabs
  R - Tread V-30
  H - Hiway
  X - XXL
  G - Greenbacks
  U - Uber
Mics
  - - 57 on axis
  / - 57 off axis
  9 - 409 Dyn
  2 - 421 Dyn
  4 - 4038 Ribbon
  1 - 121 Ribbon
  6 - 67 Cond
  8 - 87 Cond
There are 3 links below.  The first is a spreadsheet with a matrix of every possible combination of cab/mic with another, for the Tread V-30, Hiway, XXL, Greenbacks, and Uber 4x12 cabs with all available mics with the delay required to make them in-phase represented in a number of samples assuming a 96 kHZ sample rate.  The second is a list of relatively tone-transparent effects, the settings I used for my research, and the delay time in samples the effect adds to the signal.  The third is a list of a combination of effects, useful to get liquidity from the second link.
http://foobazaar.com/podhd/toneGuide/CabsDelayTimes.xlsx
http://foobazaar.com/podhd/toneGuide/FXDelayTimes.xlsx
http://foobazaar.com/podhd/toneGuide/FXCombinationDelayTimes.xlsx
EDIT: The links below replace those above.  See my last post in this thread for more details on changes.
Online Google Sheets version:
https://docs.google.com/spreadsheet/ccc?key=0AsSFadRSa9zYdG1kc1J2b1ZvRFVlUVIydXRMVVoyZnc&usp=sharing
Downloadable Excel version:
http://foobazaar.com/podhd/toneGuide/CabsDelayTimes_V3.xlsx
So here's how to apply this knowledge.  First look up any pair of cab/mic you want to use with any other cab/mic in the CabDelayTimes spreadsheet.  Channel A's cab/mic is listed on the x axis, Channel B on the Y axis.  Where these rows and columns meet, you'll see a number.  That tells you the number of samples you need to delay Channel B to get phase correction.  If the number is negative, that means you need to apply the delay to Channel A (if so, it might be simpler to simply switch the cab/mic in Channel B to Channel A and vice versa).
Once you have found the delay number, you need to add effects to channels A and B to get the specified delay.  You'll notice in the FXDelayTimes spreadsheet, the smallest delay time for any effect is 6 samples.  To get values less than that you need to add a larger delay to one Channel and a shorter delay to the other Channel.  For instance, to get a 4 sample delay in Channel B, you'd put a Parameter EQ in Channel A and a Blue Comp in Channel B.  This puts 10 samples in Channel B and 6 sample in Channel A, giving you a difference of 4 samples in Channel B.  This is where the FXCombinationDelayTimes spreadsheet is useful - you can quickly look up combinations that will yield delay samples in increments of 1 sample from 1 to 20+.
A few notes:
Even with phase correction, the bass can get a bit woofy sounding if you dial in bass on both cabinets.  I set the Low Cut Cab DEP to around 50% (260 HZ) on my "bright cab" to prevent having both too much bass and it sounding a bit "off".  The bass is going to sound cleaner and tighter from the "dark cab" anyway.
On my "dark cab", I find even with phase correction, the mixed high ends sound kinda fake together, especially when using different mics.  So I generally set the amp's Treble control to 0% on my "dark cab".
Most of the compressors additionally include a LP filter.  This is quite evident when they are applied to whichever channel you use as your "bright cab".  Thus, I try to avoid using them to delay the signal on my "bright cab".  If I need to use one to get the specified phase correction in my document, I just ignore that and get as close as I can using an EQ or something that definitely won't kill my high end.  For instance, if I need an 8 sample delay, the closest is the Vetta Juice at 7.5 samples, but I instead use a Mid-Focus EQ with 6.5 samples.  On my "dark" cab, this is not an issue.  I'm ok with dialing out the high-end there, and will use whatever gets me closest to the research.
Many cab/mic combinations are currently impractical.  Using 3-4 effects to achieve phase correction is a huge drain on DSP and effect blocks.  I hope my research isn't the end result, but a starting point for individuals to realize how powerful the onboard cab/mic sims can be if they could be dialed in as mentioned.  The real end-game is for Line 6 to implement a feature to be able to delay each channel on the Mixer block by samples in increments of 1 from 0-60.  This would require a buffer maximum of 60 samples, which at 24 bits is only 180 bytes of memory.  It should require little to no DSP, similar to the Volume effect.  Then any dual cab combination would become practical, even when using some DSP-expensive effects.
Related threads:
Feature Request
http://line6.com/support/message/390465
TheGearPage Thread about Pod HD timing
http://www.thegearpage.net/board/showthread.php?t=1138483
TheGearPage thread discussing the same effect delay phenomenon
http://www.thegearpage.net/board/showthread.php?t=964530
Edit: Some have mentioned possibly making this adjustment automatic in a feature request.  I agree.  Some effects even change their delay value, making it impossible to be manually synced.
the pitch glide is the craziest example.  when you turn it on it's at a certain number of samples, but as you use it, the exact delay changes.  so if it's at unison and there's 20 sample delay, then you move it up an octave and back to unison, now the delay might be like 30 samples.
the mid-focus eq also seems to have slight variation of its delay as you move the LP freq and Q.
i think the best case fix would be a system setting that can be set either to auto or manual or mixed.  auto would behave as you describe - the two channels are automatically synced.  manual is straight sample-based delays adjustible on either channel as i originally described.  mixed would automatically update the values, but you could set it to be always at a certain amount out of sync.
The way auto would work is it would sum the total delay in samples for each channel in real time depending on the effect, amp, and cab/mic choices.  Whichever channel had the least latency would have latency added to match the other channel.  This would occur in real-time, so that toggling effects on/off, or changing parameters would not cause the channels to become out of sync.
i think all modes would be important because when mixing certain cab/mics, some people may find the comb filter effect to be pleasing, reducing some harsh high-end.  So manual/mixed would be as valuable as auto to these people.  and some people may even want to toggle effects on/off to engage/disengage the comb filter, so they'd prefer manual over mixed.
  • drock2k1 Just Startin' 61 posts since
    Jun 26, 2009
    Sep 28, 2012 10:23 AM (in response to meambobbo)
    Re: dual cab setlist/research
    Just want to say that these findings are stellar. I hope that a L6 expert views the info and some of the feature requests make it to the HD series.
    • tdollaway Just Startin' 69 posts since
      Feb 8, 2012
      Oct 6, 2012 8:35 AM (in response to meambobbo)
      I finally got a chance to try out the "dual cab setlist" last night. Great work, man! I really like te R-_X4 combo!
      I'm usually one to use single amps, so I still have effects available. However, after trying it out last night, it's time to break out the trusty Boss and MXR stompboxes for any effects that I can't live without and use the POD mainly for my basic tone.  I really hope that Line 6 will listen to your suggestions as far as implementing both the "single amp/dual cab" configuration as well as the delay feature built into the mixer. It only makes too much sense.
      Keep up the good fight, Meambobbo! I encourage anyone to do whatever they can to CONVINCE Line 6 to take notice!
        • Astaroth_CY Just Startin' 112 posts since
          Aug 18, 2007
          Oct 11, 2012 10:50 AM (in response to meambobbo)
          These tones are fantastic. I will probably start recreating all my tones using these as the backbone. BTW - doesn't the Vintage Pre have a phase adjustment parameter? Does that basically do what you need?
  • dahla Just Startin' 3 posts since
    Jun 29, 2011
    Jan 12, 2013 5:29 AM (in response to meambobbo)
    This is the most awesome thing I have discovered about the Pod HD. Your guide Meambobbo!
    I have one question though; How do I convert the delay matrix to other sample rates? I still use 44.1, not 96...
        Jun 29, 2011
        Jan 12, 2013 10:46 AM (in response to meambobbo)
        Ah, I thought the pod used an internal SR of 48 kHz. I don't use the digital outs, so I guess if everything is 96 internally then the delay matrix should work regardless of the output sample rate. If the pod downsample at the last stage possible that is...
        Man, this is technical...!
            Jun 29, 2011
            Jan 12, 2013 12:13 PM (in response to meambobbo)
            I searched the POD HD Pro v2.1 manual and found this:
            Sample Rate Converter Active:
            You’ll see this indicator light up whenever the device is operating at a sample rate other than its native 48kHz rate. In addition to 48kHz, POD HD Pro supports 44.1kHz, 88.2kHz and 96kHz rates by utilizing an internal sample rate converter. Please check your specific software’s documentation for details on configuring its audio sample rate.
            It's for setting the sample rate when using the POD HDs interface capability... So setting the sample rate on the POD just means that your setting the output sample rate, meaning that it samples at 48 kHz at default internally, but can upsample or downsample at the last stage when using digital connections?
  • Talenless Just Startin' 64 posts since
    May 15, 43515
    Jan 12, 2013 5:49 AM (in response to meambobbo)
    is there a way to convert these patches to work with the desktop POD HD model?
  • JimKidd Just Startin' 56 posts since
    Apr 20, 2008
    Jan 12, 2013 7:15 AM (in response to meambobbo)
    Bobbo, you are an artist
