55 Views 1 Reply Latest reply: Oct 4, 2012 6:51 AM by Triryche RSS
timbone1 Just Startin' 1 posts since
Feb 13, 2011
Oct 2, 2012 5:12 PM
Not hearing selected model in recording playback
Hi, I'm trying to record in Reaper with Pod Farm using Toneport GX, I can hear the "distorted" amp effect while recording but on playback its a clean uneffected signal!
What do i need to do???
Thanks
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Oct 4, 2012 6:51 AM (in response to timbone1)
    Re: Not hearing selected model in recording playback
    In Reaper there should be 4 inputs available to be enabled in the sound preference screen.
    In the POD Farm Mixer view you can select what sends 1-2 and 3-4 send to your DAW,  processed, semi-processed, or Dry Input
    If you also have the POD Farm plug-in, a typical workflow may be to send both the processed and dry to your DAW and add the plug-in to the dry post processing.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
