418 Views 8 Replies Latest reply: Oct 11, 2012 1:45 PM by edstar1960 RSS
edstar1960 Iknowathingortwo 712 posts since
May 25, 2010
Oct 9, 2012 7:48 AM
Low Volume Mode Louder on DT25
My setup:
JTV59 - vdi - HD500 - L6link (aes/ebu) - DT25 combo
I had both channels A and B on the DT25 set to identical values for the sample AMERICAN CLEAN sound but with REVERB turned off for both.
On my HD500 I had a test patch that had BF DBL VIB PRE with default values.  I had DT25 set in Normal Volume mode and noticed I had to turn MASTER up to about 3 o'clock to get a decent volume out of it for this Fender Clean sound even just sitting at home.  I was turning the amp block on and off on the HD500 and watching the DT25 swap between channel A and channel B as I engaged and disengaged the amp block.  I was then comparing the sound of the DT25 with the sound of the amp sim via the HD500.
I decided to see what would happen in LVM - so I moved the LVM switch on the back of the DT25 to ON, the lettering on the front under the MASTER volume illuminated.  I noted that it made no difference when I had the amp sim on and I was using channel A, the volume seemed to be the same, however, when I switched the amp block off and the amp switched to channel B, then the volume increased dramatically (2 or 3 times louder) and sounded much more like a 25W valve amp at about 75% power.
I tried this a few times - the LOW VOLUME MODE made the channel B native volume very loud and did not affect the channel A volume.
Is my DT25 faulty?  Or am I doing something really dumb?
Thanks in advance.
  • geppert Just Startin' 188 posts since
    Nov 8, 2010
    Oct 9, 2012 8:14 AM (in response to edstar1960)
    Re: Low Volume Mode Louder on DT25
    I noticead exactly the same thing on my DT25 head/cab and I found it very weird. How can the LVM be louder than the regular volume mode? You're right, this happens between 50-100% on the MV. I forget exactly which of my threads were responded to but check them out for some answers. There is an explanation for it. I ended up never really using LVM. Also, the "Classic American Clean" is by far the lowest in volume of the 4 NFL's. I had to use a gain boost in the POD500 to get that particular tone up to band level. At this juncture, I find myself using the Class A Chime (Vox AC30) tone more and more. Lot's of volume there. Also, on the American Clean tone, try using "Class A" (it defaults to Class A/B). You will get a bit more level on Class A..
    There is a "learning curve" to this amp for sure.
          Nov 8, 2010
          Oct 10, 2012 9:42 AM (in response to edstar1960)
          Edstar ... oh I've read everything through and through I just couldn't remember exactly where the thread was. Glad you found it.
          Crusty (as well as others who replied) is pretty good with all this stuff.
          The DT25 is a cool amp. (I also have a SV212 but only use it as a backup amp and as a 2 x 12 cab for gigs). So far, I haven't had any of the techincal problems with the DT25 as some others have had (and detailed in various threads). It is a bit of a learning curve especially if you have the 500 (as you do). LOT's of options. As I mentioned, I don't really use LVM at all. I think a better route if you want LVM is to get a power attenuator?
          If you really like the American Clean you can get more level with the 500 but you have to do it correctly and not overdirve it. Lots of details on this forum for that. Meambobo's guide is killer. I use light compression at the end of the chain with a bit of additional output gain but lately I tend to use the AC30. Kind of like that tone for what I do.
          Enjoy your amp.
              Nov 8, 2010
              Oct 11, 2012 9:54 AM (in response to edstar1960)
              Edstar .... you are TOTALLY right on the money with the "tweekability quotient". The 500 is very deep. A local retailer told me "when a lot of my customers (especially the older crowd) hear the words "program, presets, editing, etc" they don't want to go near it". In otherwords, a nice Fender Amp with volume, tone, and reverb, is about as much "programming" they are capable of !~! I have a lot of experience with pro audio recording gear but I am still trying to tame the HD500 beast. The biggest differential I struggle with is "bedroom volume" vs "band volume". Tones are so different in those two extremes. I am starting to really enjoy the DT25 once Crusty suggested that I "think differently" about how it works. I haven't fired up the SV212 in a long time but I think I should just to get a comparison perspective. Now there's a LOUD amp !!! Like I said, I am finding the VOX AC30 to be working nicely for me at the moment. I am suprised however, that the Fender setup (Classic American Clean) is so low in volume compared to the other NFL's but I have found workarounds with the 500 to get enough band level. I would think for the most part, that plugging straight into a DT25 and trying to use C.A.C. at band levels would be virtually impossible? Sometimes, for the reserve power it offers, I wonder if I should have gone the DT50 route in the first place, but I think I am going to be able to make the DT25 work for my needs, since primarily, I am using a higher power NFL.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
