Oct 24, 2012 9:42 AM
Cannot hear anything when recording Main Mix Only
Like (0)
I recorded various inputs on my SD Card while choosing Main Mix Only? But I cannot playback the recording and nothing happens when I press the Play button. I did that on the Record page and on the Tweak page but nothing happens... What am I missing? If I choose Input And Main Mix it works though.
Thank you.
Cheers
Christian
Hi Christian,
The Main Mix does not not play back from the record page because it would conflict with the live mix. To play back the main mix:
Playing Back A Main Mix Recording
A Main Mix recording can only be played back using the Media Player in Tweak Mode. To play back a Main Mix recording, first select the Media Player icon on the stage, then press the Tweak button.
Tap the Media Player tab and the Media Player UI will be displayed. Tap the Add Files To Playlist button, then navigate the File Browser until you find the Main Mix recording you’d like to play back. Select it, then tap the blue OK button. This adds the track to the list. Now just select it and press the Play button. Your track should play back in stereo through channels 17 & 18..
Cheers,
Arne
Thank you Arne.
From you first sentence I conclude that you cannot use the Main Mix Only to change the mix while listening to it. Am I right? Or maybe I don't understand why "it would conflict".
I wonder if access to the playback of the main mix shouldn't be more intuitive.
