91 Views 1 Reply Latest reply: Dec 30, 2012 6:27 PM by FuzzExplosion RSS
html Just Startin' 1 posts since
Oct 24, 2012
Oct 24, 2012 10:27 PM
FM4 synth settings problem
I just got an FM4 and it works awesome for the most part...one thing that seems flaky to me is the synth settings.
It's like they aren't really working right or something.
The volume is considerably lower and almost non-existent even after resetting to factory specs and playing with knobs. I can hardly get any volume out of any of these specifically; • Octisynth / • Synth-O-Matic / • Attack Synth / • Synth String
Is it possible there's a problem with the pedal that would affect only these particular settings? It seems all others work fine.
  • FuzzExplosion Just Startin' 3 posts since
    Oct 26, 2009
    Dec 30, 2012 6:27 PM (in response to html)
    Re: FM4 synth settings problem
    Still having issues? I'm surprised to see no one has responded to this. Almost all the mentioned effects are triggered by attack, if you play too fast it might not be giving the effect time to process, or if your guitar has too low of output, you might not be hitting the effect threshold. I use all of these effects and they don't work the same with all guitars. TIPS: Use the neck pick-up, play around the 12 fret and keep your volume all the way up. Also turn the attack all the way down and you might be able to get away with playing a little faster if thats the case.
    -Scotty
