1 2 3 4 ... 11 Previous Next 6484 Views 156 Replies Latest reply: Dec 4, 2012 4:58 AM by TheRealZap RSS Go to original post
  • ReverendLove Just Startin' 95 posts since
    Mar 23, 2007
    15. Oct 30, 2012 2:11 PM (in response to TheRealZap)
    Re: DT 2.0!
    Yes, you're right. But you can control the MIDI ports on your windoze. So - MidiOX is probably more simple.
    Mar 23, 2007
    17. Oct 30, 2012 2:18 PM (in response to TheRealZap)
    Re: DT 2.0!
    No problems here. I am used to configurate devices via MIDI.
    But I would like a tiny Toy for my android. - I keenly hate things starting with a little i followed by a capital.
  • sopachrga Just Startin' 80 posts since
    Apr 21, 2006
    18. Oct 30, 2012 2:27 PM (in response to ReverendLove)
    Re: DT 2.0!
    Has anyone tried installing the update yet? How long did it take?
    Mar 23, 2007
    20. Oct 30, 2012 2:32 PM (in response to TheRealZap)
    Re: DT 2.0!
    Yes. No problem with the update. Used a Cakewalk UM-3G as interface.
    Apr 21, 2006
    21. Oct 30, 2012 2:38 PM (in response to ReverendLove)
    Re: DT 2.0!
    Awesome, will try it tonight once I get home from work.
  • RPascarella Just Startin' 30 posts since
    Feb 19, 2009
    22. Oct 30, 2012 2:41 PM (in response to TheRealZap)
    Re: DT 2.0!
    Cool!  Wish my amp was back from the shop!  Still waiting for a replacement power transformer from Line 6.
    Anyone know what this means from the release notes?
    - Configure XLR Direct Output Mic Emulation
    Also, just to be sure, if I use my HD500 into my DT50, these features probably don't get me anything more than before, right?  They are geared towards standalone amp use without an HD?
    Feb 19, 2009
    24. Oct 30, 2012 3:07 PM (in response to TheRealZap)
    Re: DT 2.0!
    I was hoping you'd say that!  But I'm still confused.  If my HD uses PRE amp models, it doesn't control cab and mic modeling, right?  So to use this new XLR config feature, sounds like I would need one of the following:
    1) HD with FULL models, or
    2) HD with PRE models and a MIDI controller/software, or
    3) MIDI controller/software only
    Does this sound right?
    And would it be correct to say that, prior to this update, the XLR mic emulation was already controllable when using the HD with FULL models (that is, #1 above)?
    Mar 23, 2007
    25. Oct 30, 2012 3:26 PM (in response to RPascarella)
    Re: DT 2.0!
    It is like it was before with the HD. These setups only work with the HD and are temporary on the DT.
    If you disconnect L6 Link DT goes back to its own configuration. This "permanent" confoguration for the DT alone can be changed by CC changes via a MIDI connection.
    That makes sense with the MIC configuration too because the speaker and the microphone are simulations on the XLR out and for mixing purposes.
    Hope I am right, but it only makes sense this way.
  • greghall Just Startin' 160 posts since
    Feb 2, 2007
    27. Oct 31, 2012 2:46 AM (in response to TheRealZap)
    Re: DT 2.0!
    other than the internal corrections...
    Very mysterious
    Does this mean that when I select a pre-amp model on the HD, there is now some internal adjustment in the DT power amp settings (other than the topology settings)?
  • WardMan Just Startin' 4 posts since
    Jan 26, 2007
    28. Oct 31, 2012 2:55 AM (in response to TheRealZap)
    Re: DT 2.0!
    Wow, this is great news. I bought my DT-25 last Friday and was happy with the standard 4 models and had just started to look into the MIDI switching. I've got a Behringer FCB1010 MIDI footswitch that has been gathering dust under my desk - it's now all cleaned up. I'll update the firmware tonight and start experimenting with the MIDI. There's some great models now available that I'm familiar with on my X3L.
    Feb 2, 2007
    29. Oct 31, 2012 3:24 AM (in response to ReverendLove)
    Re: DT 2.0!
    As the HD500 is also a MIDI Controller, I guess you could use the L6 and the MIDI interface in paralellel to control the DT settings, e.g. if using a no amp patch or switching the amp model off to use channel B in the DT?
    Does this work?
Bookmarked By (1)
