176 Views 3 Replies Latest reply: Nov 13, 2012 6:45 AM by phil_m RSS
886343 Just Startin' 34 posts since
Feb 26, 2007
Nov 13, 2012 3:23 AM
M9 FX Routing
Reading the M9 manual it states you can have the fx routing either 1>2>3 or 3>2>1,
I run my M9 in the amp fx loop and my question is this, I currently have the M9 set as 1>2>3 with 1 = chorus, 2 = delay & 3 = reverb or tremolo.
When the M9 is in the amp fx loop does it matter which way round the routing is like it would say if it was in front of the amp (i.e. inline not in the fx loop)
Traditionally you would have delay at the end of the chain so should I set the routing to 3>2>1 and have 3 = delay, 2 = chorus & 3 = reverb or tremolo. I am presuming here that the chain would be amp fx send > 1 > 2 > 3 > amp fx return? Is this correct?
Getting a bit confused with it....
Thanks
Michael
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Nov 13, 2012 6:27 AM (in response to 886343)
    Re: M9 FX Routing
    This setting doesn't really have anything to do with the way you arrange the effects within your scene. Since you can put any effect in any slot in the M9, you can put your effects in any order you want. What the 1<2<3 or 3<2<1 setting does is determine how the signal flow goes through the pedal itself. The default is 1<2<3, but going left to right is the opposite way most people have the signal going on pedalboards. Almost all pedals have the input jack on the right side of the pedal and the output on the left. So the signal ends up going from right to left. Setting the M9 to 3>2>1 will make it so the effect in slot 1 is the last in the M9's signal chain. Flipping this setting won't actually change your tone at all, though. The M9 automatically moves the effects that were in slot 1 to slot 3 and vice versa.
        Jan 25, 2007
        Nov 13, 2012 6:45 AM (in response to 886343)
        Re: M9 FX Routing
        Yes, put your effects wherever you want them. If you want your delay last, and you have the M9 set to 1<2<3, it would go in slot 3. If you had it set to 3>2>1, you'd put it in slot 1.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
