112 Views 1 Reply Latest reply: Nov 13, 2012 9:27 AM by phil_m RSS
MelThorpe Just Startin' 28 posts since
Aug 6, 2012
Nov 13, 2012 9:16 AM
Wah Question
I have the Shortboard with the HD Pro and the expression pedal works great for volume and for wah, but how do I get it set so that when I press it down to turn off the wah it actually turns off the wah and doesnt leave it set to wide open? Right now it changes it back to a volume pedal, but it leaves the "tone" of the wah as if I had it all the way open. If I click the toe button, I want it to turn the wah off and switch back to be the volume pedal.
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Nov 13, 2012 9:27 AM (in response to MelThorpe)
    Re: Wah Question
    You have to select the expression pedal toe switch as the on/off switch for the wah effect. In HD Edit, this is on the Controllers tab. Selet the wah model, and right below it you'll see the "FS ASSIGN" pulldown. Select the "EXP TOE SWITCH" from there.
