263 Views 7 Replies Latest reply: Nov 27, 2012 7:26 PM by brue58ski RSS
adessmith Just Startin' 119 posts since
Jan 6, 2009
Nov 21, 2012 6:10 AM
Disappointed in Pod integration
Unless I am missing something, I cant find a way to switch back and forth between mags and models via the POD.
I am using the JTV-59 with the X3L (not the HD500) via VDI... but I doubt this can be done on either...
For instance, all my "go-to" patches on my X3L use the magnetic pickups except one, which is based on the American Classic preamp, with a little tweaking to the eq, some compression, etc... and set to force the D28 model. If I play patches using the magnetics first, then hit the patch for the acoustic it does not engage the modeling function. I have to manually push in the modeling knob to engage the modeling and THEN hit my footswitch.
Is this right? The only soulution I can find is to reprogram all the other patches to only listen to the variax input #2 (mags), and make sure I remember to engage the modeling function as a habbit when I pickup the guitar.
Only problem with that (aside from having to remember something) is that I loose the option of manually engaging the modeling on the other presets because it will ignore variax input #1.
For instance, I typically use patch 1A (nice warm clean tone with a little delay) with the magnetics, but just for the heck of it I may decide I want to try the strat model on this patch... If I use this solution I would have to change the input settings to get the X3L to listen to variax input #1 on that patch.
There has to be a better way. Seems like there would be a function that forces modeling on if you select a patch that forces a particular model.
So far, the only benefit I am finding to VDI is I can ignore the battery (which will likely fail prematurely because it's not being utilized)
Now I'm really sorry I ditched my relay G30 to help fund my JTV-59.
  • Rewolf48 Just Startin' 133 posts since
    Aug 9, 2010
    Nov 22, 2012 5:10 AM (in response to adessmith)
    Re: Disappointed in Pod integration
    I don't know about the X3L, but it works perectly with an HD500 - the Model mode is automatically active when the VDI is connected.
    I never need to press the model/mag switch on the JTV, but my patches are set-up to use either Variax Mags (that is what it is named on a HD500) or the Models, and when on Models I have the choice of forcing to a specific Model (and locking the controls and changing the tuning).
    Are you sure you have the recent firmware updates? (at least 1.8 on JTV)
    • davidb7170 Just Startin' 253 posts since
      May 3, 2008
      Nov 24, 2012 7:19 AM (in response to Rewolf48)
      I now have the HD500 -- since last May, but was using the X3L for a few years prior and keep it as my backup for gigs. The X3L does function well with the JTV, but is a bit frustrating in that to set a patch to switch the JTV models, you have to do it manually on the X3L, not with the Gearbox software. The software will work to set models on the 1st generation variax (I have a 300), but not with the JTV's. It's a foible of the software, not the X3L. Switching between mags and models for different patches is not just a part of the X3L as it is with the HD500 -- but only within the last few months or so since a firmware revision to both the JTV & the HD500 made it possible.
      You either have to switch manually, or possibly use the input choice for the JTV/X3L -- can't remember the details, but there are two channels to choose from on the inputs that represent the mags & models. I always just set Channel 1 & used manual switching, but it seems you can use the JTV mags & models together even on the X3L, so you should be able to use one channel for the mags for some patches and the other for the models for other patches... Some one in the X3L support group may be able to describe it better.
      I also use the mags for the majority of the time. I have the 59, and just recently got a 69S.
      Dave
          May 3, 2008
          Nov 26, 2012 6:05 PM (in response to adessmith)
          adessmith --
          It did catch me that way, too, I either forgot to turn on the modeling, or turn it off. I got to the point where I would write on my setlist "1d - VAX!!" in big letters to remind myself.... And I had to set up custom Variax settings with the tuning for anything that needed them. It was a pain, but I put up with it for about a year after getting the JTV. I tried an HD500 a year ago Labor Day - 15% off sale at Guitar Center, but got a flakey one and took it back, and swore it off, then last Memorial Day -- Guitar Center had another 15% off sale, and I tried again. This time the unit was good, and the latest update at the time had the feature of remembering how you saved it with the patch -- model on or off, whether you forced a specific model or not. To me, that was worth the price of the HD500. The amp models are good, but not what I consider head & shoulders above the X3L for the ones I use, and it had some of the FX missing that I really liked like the synth patches -- fought with that one & still not as good as what I had going on the X3L... Etc. Yeah it's a mixed deal -- some things I like better, some definitely not...
          Dave
  • brue58ski Just Startin' 287 posts since
    Jan 24, 2007
    Nov 26, 2012 4:15 PM (in response to adessmith)
    I am also VERY disappointed in the integration of The JTV to the X3 and the Vetta.  Yes it works with it half assed but I think it could be worked/programmed to have the same integration as the HD500 with the exception of the retuning. Basically the same integration as with the first Variax. Mainly being able to program it with patches from Gearbox. Line 6 has a slight reputation for completely dropping things without finishing them once they've moved on to the next thing.  And with little to mostly no notice.  Like with the JTV integration, I saw that "Yes the JTV will work with the X3Live", got my JTV only to find out it yeah I suppose it does but not in the same way as the first Variax, which is what I was expecting.  Then, "We're not supporting the X3Live anymore" which means i'm our of luck as far as it getting to the older Variax point.  It's one of the few, if not only, major disappointments about this company. To me it's a big one.
        Jan 24, 2007
        Nov 27, 2012 7:26 PM (in response to adessmith)
        At the VERY least they should have made the JTV compatible with the X3L and Gearbox in the way the old Variax was.  I can understand not keeping it compatible with the XT and the Vetta but when the JTV came out, the X3 Live was still selling and (supposedly) still being supported.  Basically I feel like I've been tricked.  And this isn't the first time Line 6 has made me feel this way.  I too am a Line 6 boy but the JTV and the HD500 are probably my last Line 6 purchases.  I mean look at their new sound system.  It looks sooooooo cool.  I would love to get into it.  But it relies so heavily on "computing" that given Line 6's past with support of products I can't justify the expense.  It's alot of money to spend on software that, given the track record, won't be supported in 5-10 years.
