239 Views 5 Replies Latest reply: Nov 27, 2012 12:16 AM by Tyrrellr RSS
csr1 Just Startin' 2 posts since
Jan 16, 2011
Nov 25, 2012 2:40 AM
POD HD 300
Two Questions:  I bought a Spider 75 almost 2 years ago and I'm very happy with it, great tones.  Three weeks ago  I bought my new POD HD 300 for cleaner and quicker home recording when quiet mic'ing isn't possible, and also because I maybe playing soon in a setting in which amps aren't used and everybody goes direct into the mixer. Question #1, is there any easy way possible through Line 6 Monkey or any other way to copy or re-create into my HD 300 some of the tones that I've created in my Spider 75?   Would I have to pull up my HD 300 Edit and my Spider 75 Edit side by side on my computer screen and compare the amps, cabs, and effects and then manually create them on the hd 300...is that even possible?
Question #2  In addition to the studio/line setting on my hd 300, how and what settings or patches should I have my Spider 75 set to if I want to use it as a cabinet/monitor when connected to my hd 300?  I know that the switch on the hd 300 should be set to line if connecting it to an amp/combo amp? Should I turn on the manual switch on the Spider 75?
Thank you for any help or advice that I can get on this.
  • PremiumJones Iknowathingortwo 238 posts since
    Mar 29, 2008
    Nov 25, 2012 6:31 PM (in response to csr1)
    Re: POD HD 300
    Answer #1 - Youll have to sit there with the Edits open and try to recreate them.
    Answer #2 - The Spider 75 has no FX loop, so you dont want to use Line. Line is for going straight to a power amp or Line level FX return, which you arent doing. You are plugging into the front end of the Spider, so you need the Amp setting.
    Then you need to start with the Output Mode switch on the back set to "Live" and then in the Setup menu, set the Live output sheme to ComboFrt
    You will likely want to use Preamp models rather than full, with no cab or mic.
    Experiment with all these settings though, you may find that full models with Live Output set to StackAmp is the best. Or preamps only, but using Studio/Direct Output Mode might be good, or whatever, Mess with it some.
    Finally, you should realize that using the POD HD this way is far from ideal. You will most likely not be happy with any tones you get using the POD into the front of any guitar amp. Unless you can bypass the amp modelling in the Spider (which I am not sure of) you are always going to be putting a pre-amped, tone shaped signal into another preamp, which is going to make it sound different. That could be a good difference in some cases, but it is almost always bad.
    Ideally, you'd want to use the POD in one of three setups:
    1. Into the FX return or Power Amp In on a combo amp or head connected to a cabinet.
    2. Connected directly to a dedicated power amp running a cabinet
    3. Using Full models, Studio Direct mode, into a PA or other FRFR setup.
    Assuming you only want to use it as a monitor for live situations where you are going through the PA, you'd probably wanna use Dual output mode, sending the Studio/Direct side to the PA and the Live side to the amp... it still wont sound good, but you can at least hear what you are playing that way.
  • Tyrrellr Just Startin' 12 posts since
    Jan 11, 2008
    Nov 27, 2012 12:16 AM (in response to csr1)
    Re: POD HD 300
    Hmmm....my HD 300 suddenly won't boot up. Get a message that says "DSP boot failed" then screen just goes blank. I had installed latest software updates. Could be something to do with that? What now??
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
