201 Views 5 Replies Latest reply: Dec 3, 2012 1:02 PM by variaxlover RSS
randkell1 Just Startin' 2 posts since
Dec 6, 2011
Nov 27, 2012 8:00 PM
Dream rig connections and settings
I just received my jvt-69 to add to my hd500 and dt25 and I am struggling trying to find the best way to connect my guitar to get the best sounds from the guitar model settings. I have the guitar connected to the pod using the digital cable and the link between the pod and amp, but the modeling does not sound like what I have heard on online videos. I am looking for some input from the forum.
1. Do I use the digital cable or the 1/4 inch instrument cable into the hd500?
2. What settings do I use on the hd500?, do I need to use certain amps or is there some type of bypass? Or do I just connect it and it takes over?
3. Do I need to do anything on the amp? Will it automatically switch the amp to the type of amp needed for the modeled guitar?
I am new to amps and pedals, so I purchased the dream rig because of how it was integrated and is supposed to reconfigure at the turn of the knob. By the way, I connected it to a Roland cube with the 1/4" cable and it seams to work and sound on the videos.
Line 6 has pilot guides for all of these items and advanced guide for the hd500, they need at pilot guide for the dream rig!!!
  • nd_mustang Just Startin' 41 posts since
    Dec 22, 2009
    Nov 27, 2012 8:18 PM (in response to randkell1)
    Re: Dream rig connections and settings
    Between the HD500 and DT25, I'd suggest the L6 Link (Planet Waves mic cable if nothing else, special digital version if you can do it).
    Between the HD500 and the JTV-69, I'd suggest the digital cable, but it isn't as critical.
    The biggest issue is setting up the HD500 like you like it.  That's the "hard part" - not that it's hard, you just need to understand what you're doing.  Start with the amp that you are after - I've recently fallen for the Soldano models pretty hard, but I play mostly classic rock - EQ it a bit, add a bit of reverb to give it some body, don't get crazy on any of the controls (I never "max" out things like drive or presence) - turn off the cab simulation (no need, and gives you more processing power for effects) - and then I typically look at things like tube drive (I leave "off" after I add it and usually assign it to FS1) and any cleanup EQ needed on the backside.  Then I use the mixer to give me the volume I want.
    I would strongly suggest a THD Hot Plate (or similar) if you want a good distorted sound because you can "crank" the tubes, but mute the sound.
    Finally - personal preference - but I didn't like the factory tubes.  Lately I've been running Northern Electric 12AX7 tubes for Pre and Tung-Sol EL34B tubes for Power.
    If you want me to email you a clean/crunch/heavy patch, just let me know your email.  What I like is my clean patch, when I hit FS1, then it's a good classic rock distorted sound with lots of reverb.  When I use my crunch, it's a good 70's/80's sound, add the FS1 (tube drive) without so much reverb.  And my heavy sound is more current rock/metal - hit F1 again for gobs and gobs of sustain!
    Anyways, that should help.
  • scotty_burford Just Startin' 89 posts since
    Sep 14, 2009
    Dec 3, 2012 12:50 PM (in response to randkell1)
    It can be a very steep learning curve when you are starting out effects and the like.
    A good place to start would be getting a basic tone withouht too much in the way of effects. Listen to the amp models and see what they do.
    I think it can be quite useful to look at a player's rig you admire, see what they are using and maybe try that as a starting point.
    Do a search on Google for some ideas of effects chain as well. Placing the distortions before the preamp is typical, with time and pitch effects going after.
    For the most part, using effects to enhance the sound is best (IMHO). Sometimes a sound can be great with something maxed out, but they is typically not that useable in a song when playing with others. It doesn't tend to fit that well.
  • variaxlover Just Startin' 323 posts since
    May 19, 2007
    Dec 3, 2012 1:02 PM (in response to randkell1)
    After trying the dream rig last year, ditching it and reading endless complaints about how it doesn't work all that well, I have a suggestion:
    Assuming you want to keep your Variax, get yourself a Vetta II and a Longboard.  Tweak the sounds just a bit, then sit back and enjoy trouble free operation.  You'll get 99% of the great sounds you MIGHT eventually find in the dream rig, with 1% of the headaches and at 1/4 the cost.
    Line 6 should have never abandoned the Vetta.  I got one of my two Vettas out of the closet the other day and plugged in my Longboard and Variax transplant -- instant satisfaction and FANTASTIC sounds!  Something to think about, folks.
    Line 6, a Vetta III could be your biggest seller ever if you market it right. PLEASE consider this!
