371 Views 8 Replies Latest reply: Dec 23, 2012 3:51 AM by Rblay2k RSS
thisjanuary Just Startin' 25 posts since
Oct 13, 2006
Nov 29, 2012 10:45 AM
Nasty crackling feedback when recording in Logic Pro 9 with POD X3?
Plugged my POD X3 (bean, latest drivers, just updated today) in via USB and am trying to record into Logic Pro 9. I have my POD X3's Left and Right outputs plugged into a Focusrite Saffire PRO 14, which my speakers are connected to, and I've got Logic using the POD for Input, and the Saffire for Output.
Created two tracks in Logic, one Input 1 (which is the wet sound from the POD's on-board effects), and one Input 7 (which seems to be the dry input).. getting this nasty buzz on both tracks. Here's an example – what's going on with it?
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    If you are running the POD's analog L&R into the Saffire, then you should also select the Saffire as your recording device in Logic. In that scenario the only thing you would need the USB for is to Edit the POD via Gearbox.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    The Pod X3 ASIO uses an ASIO driver. The definition/implementation of the ASIO protocol requires that the same device be used for both audio input and output. You can record both wet and dry signals simultaneously in Logic Pro using just the X3 - not your Saffire. Set it up as follows:
    - connect the X3 to your computer using USB
    - connect your speakers/monitors to the X3 outputs
    - configure Logic Pro to use the X3 and its ASIO driver as the audio input/output device
    - arm two tracks for recording
    - select different Input Source feeds for the two tracks. For the dry track, select X3 Input Source 7 (Tone 1) or 8 (Tone 2); for the wet track select the desiredX3- processed signal (1,2 for the stereo mix; 3,4 for Tone 1; 5,6 for Tone 2)
    Feb 20, 2007
    Also.. your comment didn't really answer my question.
    To answer your question, the configuration you stated creates a conflict with the audio bit stream.
    My apologies for not answering the question, guess I just jumped directly to tyring to help you find a workable solution.
    btw, are you running a pc or Mac?
  • Metal_Jimmy Just Startin' 1 posts since
    Dec 16, 2008
    im getting the same problem! at first i thought it was cause of my gain levels but even with everything turned low all i was getting was this weird noise. then i thought it was something with my guitar jack so i tried a differient one and same result...
    Feb 20, 2007
    Can you run Logic on a PC? Yes. Is it practical, probably not.
    If you have a mixer you would not need to switch back and forth. I have 4 interfaces into one mixer and my monitors are connected to the mixer.
    Your are correct, there is no ASIO in the Mac world, it is CoreAudio. If you are using Mountain Lion, it might just be the drivers, since Mountain Lion some (not all) Mac users are having driver issues. Line6 is currently working on this.
    You can contact Line6 directly via a support ticket or phone:
    http://line6.com/support/tickets/add.html
    Line 6 - North America
    Line 6, Inc.
    26580  Agoura Road
    Calabasas, CA 91302-1921
    Main Phone#: (818) 575-3600
    Main Fax#: (818) 575-3601
    Customer Service hours are 8am - 5pm M-F Pacific Time
    Press option 3 for Customer Service
    Our busiest hours are from 11am to 2 pm.
    Line 6 - Europe
    Line 6, Inc.
    The POD
    Clifton House
    Butler's Leap
    Rugby, Warwickshire
    United Kingdom, CV21 3RQ
    Telefone: +44 (0) 1788 566 566
    Fax: +44 (0) 1788 566 529
    Technical Support: +44 (0) 1788 566 555, Mon-Thurs 9am – 5pm GMT and Fri 9am – 4pm GMT
  • Rblay2k Just Startin' 9 posts since
    Jun 13, 2008
    This is a temporary fix I used... http://youtu.be/EsYAyVF_V6M
    Hopefully this helps?
    Bob
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
