195 Views 2 Replies Latest reply: Nov 30, 2012 6:41 AM by Mbalsan RSS
Mbalsan Just Startin' 7 posts since
Apr 13, 2012
Nov 29, 2012 10:52 PM
DT50 Problems after trying firmware update
Hi.
So I tried to update my DT50 Head today. I followed the instructions and everything seemed to work fine and the update started. Suddenly, there was an error and Line6 monkey couldn't recognize my device anymore , and it did at the beginning . Now the amp switches don't answer. I can't switch topologies or anything. Both Class AB and Class A are lighted up, and it seems to be stuck. The amp doesn't make that starting up "click" it used to make. Line 6 Monkey can't recognize the device anymore, and instead it says it is a DT50 112. I can't update it (error 8000000A) and what it's worse, I can't even play it. I was using a brand new Alesis Midi Usb Interface. Any help would be much appreciated. Thanks a lot in advance.
  • sopachrga Just Startin' 80 posts since
    Apr 21, 2006
    Nov 30, 2012 1:20 AM (in response to Mbalsan)
    Re: DT50 Problems after trying firmware update
    I had the exact same issue. I rang Line 6 support and this is what they got me to do to fix it.
    -Power the amp off
    -Disconnect Midi cables from the amp (and all other cables, so you only have a speaker and power cable connected)
    -Hold the Channel selector switch down (towards channel B) then turn the main power switch on (Just leave it in standby)
    -Continue holding the channel switch for a good six seconds. (Nothing will happen to indicate that you have held it long enough)
    -Then release the channel switch
    -Plug the midi cables back in (leave the amp switched on)
    -Start Monkey back up
    That worked for my DT50
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
