112 Views 2 Replies Latest reply: Nov 30, 2012 11:11 AM by drraven RSS
drraven Just Startin' 7 posts since
Nov 28, 2010
Nov 29, 2012 8:24 PM
Flextone II HD static & buzzing after cleaning pots & new battery
Picked up a Flextone II HD amp earlier this week and I was told by the seller that when he last used it several months ago it would work for a while, sometimes an hour or more, and then it would power off. So he put it away to collect dust. I tried the amp before buying it and it worked and sounded fine for the 10 mins I tried it. I then took it home and played it a couple of times, both for about 30 mins with no problems, but I noticed it wasn't holding any of the patches. So I did some research and replaced the CR2430 coin battery (the orig battery measured 0.00V). This procedure requires removing a large metal cover over the electronics and several screws, so I figured while I was inside the amp I should spray electrical contact cleaner into all of the pots. I was very careful not to touch anything else or move anything. I then carefully reassembled the amp and now when it powers on I get a constant static & buzzing sound that pulses in time with the tempo button setting. I can turn the Master volume off and the buzz/static stays the same volume. If I turn the Master volume up and play my guitar I hear my guitar signal and it sounds normal except for the static/buzz in the background. Not sure why spraying the pots and changing the battery would have caused this, but has anyone else run into this problem? Thanks.
Andy
    Dec 22, 2006
    Perhaps you got some cleaner on other circuits? might need to dry out or clean up? just an idea... i certainly don't think that changing the battery would have cause the issue.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
