270 Views 6 Replies Latest reply: Dec 23, 2012 8:52 AM by jjRocker RSS
anouchirvan Just Startin' 38 posts since
Jan 22, 2011
Nov 30, 2012 5:19 AM
Electric guitar EQ
Hi
I use POD Farm2 with my Line 6 USB UX2 interface. I like the FX but whatever FX I put on the Electric Guitar, I have a problem to have lower strings as well as higher strings sound good simultaneousely.
That is, when I tweak the sound/FX to have a good sound on bass strings (say 3rd to 6th strings), then the lower 1st and 2nd strings sound too high, too metallic or crystaline.
On the other hand, when I make it to have a good sound on 1st and 2nd strings, the bass strings sound too boomy.
This worsens when I add some distortion; that is the 1st and 2nd strings' sound are so ear-penetrating that I have to lower the volume!
Can any EQ settings and/or other tricks get around this problem ?
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
    Dec 1, 2012 2:57 AM (in response to anouchirvan)
    Re: Electric guitar EQ
       Here's the eq setting I set for all my electric guitars - in the  4 band EQ in pod farm I use -   -4.7db at 50hz, 9.5db at 100hz, -3.8db at 550hz and -5.6db at 9.0khz
    I keep that on that and then adjust the amp etc.
    This might not suit your personal choice, but I settled on that after trying to get overdriven/distorted amps to sound better. I wanted to get rid of the 'fizzy' sound.
    God bless,
    David
        May 12, 2011
        Dec 3, 2012 6:20 AM (in response to anouchirvan)
        Yeah, I hadn't thought of that. I used to have same problem. I used to get booming bass strings and I'm not sure if I changed my amp's tone to stop it but I later changed my pickup height and I think I got it solved. This guitar has humbuckers in the bridge position and single coil pickups in mid and neck positions, so I put my humbucker up closer to the strings (sloping down to bass side) and my single coils lower - neck lower than mid so that fretted strings when played at 20th (or 21st - can't rmember how many it has) won't hit the neck pickup poles.
        I tried really lowering the pickups on another guitar and I know what you mean . It really gives you a different sound and volume, and feels quite different. Having it lower allows more vibration and 'instrument' sound (that's not really totally true I suppose but I just mean more 'vibration', and having them up close makes the magnets 'pull' on the strings and so the sustain of notes is reduced because the strings are being stopped from vibrating a bit, because the magnets in the pickups are pulling at them. I use the higher up pickup for higher gain stuff especially, where I want more db  - but it just depends on what sound each person is after. I like distortion/overdrive but I also like cleaner sounds too, so I like both types. I don't use the guitar I 'really' lowered though, as it has problems.
        Have fun searching for that 'sweet spot' where it sounds right.
        How many pickups do you have and are they all the same type? Maybe you could try one higher and one lower etc.
        God Bless,
        David
            May 12, 2011
            Dec 4, 2012 4:47 AM (in response to anouchirvan)
            Yeah. the normal strat sound is single coil pickups, and strats are lighter guitars than Les Pauls (and I suppose the L6s ) etc. so they resonate differently, but if you were really keen, you could re-wire the humbuckers so that depending on which switch position you have it set on, it will give a full humbucker tone or a sound similar to single coil pickups. You probably wouldn't want to do this though to your good guitar though, but its an option.
            Concerning pickup height, yes, it wouldn't be good to have to change height each time you wanted a different tone. Yes, I think you would have to find the best height and then change your effects settings for the new position.
            God Bless,
            David
    • jjRocker Just Startin' 5 posts since
      Oct 21, 2006
      Dec 23, 2012 8:52 AM (in response to hulbert)
      hulbert schrieb:
      God bless,
      David
      Thank you for the advice ! Makes it much easier to dial in a good distortion sound
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
