88 Views 1 Reply Latest reply: Dec 1, 2012 1:55 PM by Rowbi RSS
biffothebrave Just Startin' 2 posts since
Dec 1, 2012
Dec 1, 2012 8:39 AM
Spider Mk1 40 watt valve combo.
Hello all.
Just bought a Mk 1 valve combo second hand without an instruction manual.
Boy do I have a problem.
Switch it on, volume is flat out.
Press any of the four saved pre sets and it blows you across the room.
Have tried the factory reset and it makes no difference.
What gives?
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Dec 1, 2012 1:55 PM (in response to biffothebrave)
    Re: Spider Mk1 40 watt valve combo.
    have you turned the master volume down?  That's where I'd start, unless you've done that already.
    you can download a copy of the manual, via the support link at the top right of this page.  But here's the link for you: http://line6.com/support/manuals/
    You should be able to work out what settings are stored within the presets using the blink out method, and then turn down the channel volume (which is the volume setting that's saved in the preset).  The master volume and presence controls aren't saved in the presets, they're 'master' controls that react to where the knobs ont he amp are positioned.
    Hope this helps for a start
    Rowbi
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
