Dec 2, 2012 11:20 PM
Trouble with flood pod plus pedal
Like (0)
these are the instructions that i did to my flood pod plus ..
Floor Pod Plus
1 Hold toe-switch on VOL/WAH and power unit. The display will read ?PC? (Pedal calibration) and then ?000?.
2 With the pedal at toe-position, hit the ?A? button. The display will show 100
3 With the pedal at the Heel-position, hit the ?B? button. The display will show ?100?
4 Press footswitch C to read the numeric values. Press pedal-toe switch on and observe lights around effects encoder, which will reveal the pedal position.
5 Press and hold tap switch for 2 seconds to save calibration.
but, at the step 4 "Press footswitch C to read the numeric values. Press pedal-toe switch on and observe lights around effects encoder, which will reveal the pedal position." the lights around effects encoder not reflect with the pedal position , the lights still off ..
so the pedal can't reflect when in toe or heel . how must i did ?
now i can't used the pedal . if i hold toe switch, the light "wah" is on.. but give no respon when i play the pedal .. please help . thanks ..
