90 Views 3 Replies Latest reply: Dec 21, 2012 2:56 PM by silverhead RSS
xCorpsemanx Just Startin' 2 posts since
Mar 9, 2011
Dec 21, 2012 2:36 PM
Trim input on line 6 pod x3 is for hi z input??
im asking this because i cannot find an answer anywhere that makes any sense to me .... so basically im wondering is the out on my pod x3 that says TRIM  INPUT 2 .. is that for hi z ? im basically trying to figure out a way to fix my latency issue in my daw when recording and when i use amp simulators like amplitude , th2 , ampeg ... stuff like that .. im very aware that my line 6 has killer sounds on its own but i also like to use it as an audio interface for the amp sims.. if i wasnt clear enough on my question please let me know so i can elaborate further..
would this cable work for what im trying to do? www.musiciansfriend.com/accessories/musicians-gear-musicians-gear-20-foot-hi-z-mic-cable?sB=r&question=Hi-Z+Cable/
thanks in advance.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Dec 21, 2012 2:36 PM (in response to xCorpsemanx)
    Re: Trim input on line 6 pod x3 is for hi z input??
    The X3 has a PAD switch for the guitar input, meant to be used with hi-gain inputs. It is in the top right section of the X3 top panel.
    From the user manual:
    Guitar In Pad – the Off setting of this switch is appropriate for most guitars.
    If you see the Cliplight coming on, that means you’re overloading POD X3 Live’s input.
    If that happens frequently, try the On setting here. This switches in input circuitry that’s
    appropriate for hotter signals output by some guitars with active pickups, or from keyboards
    and other sources.
    Frankly, though, I don't see how this might affect your latency issue. Tell us more about your recording setup. Are you using the X3 as your audio interface? How are you monitoring the sound? Is the Reocird Monitor feature turned on or off in your DAW?
        Apr 1, 2009
        Dec 21, 2012 2:56 PM (in response to xCorpsemanx)
        OK - using the X3 as your audio interface, the first thing you need to do is to connect your speakers/monitors to the X3 audio outputs. The X3 becomes your soundcard - your internal soundcard in your PC is bypassed.
        Next, make sure that fruitloops is configured to use the X3 and its ASIO driver as the audio input/output. device. There will be some audio setup/configuration window in fruitloops for this; I'm not familiar with it so can't tell you exactly where it is - go on a hunt. Similar thing with the record monitoring feature in fruitloops - find it and turn it off.
        Hope this helps.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
