103 Views 1 Reply Latest reply: Dec 27, 2012 7:11 AM by Krontab RSS
PaulJam Just Startin' 42 posts since
Feb 16, 2011
Dec 25, 2012 10:53 AM
DT25 112 combo humming
Hi
I just got a new DT25 112 combo.
As soon as the amp is on I hear some low frequency hum from the speaker.
The humming does not change when i flip the standby switch or change any of the other settings (like clas A/B - class A or penthode - triode).
The humming is not very loud, but it is loud enough to be annoying when not playing (it can be clearly heard from 4-5 meters distance in a calm environment).
My friends amp (Mesa Boogoe Mini Rectifier) is much more silent  (a little hum can be heard only when holding the head directly in front of the cabinet).
Also, when i turn the amp off there is a loud pop coming from the speaker.
Is this normal for the DT25 or could there be something defective?
  • Krontab Just Startin' 201 posts since
    Mar 15, 2006
    Dec 27, 2012 7:11 AM (in response to PaulJam)
    Re: DT25 112 combo humming
    The pop is normal if you do not put it into bypass and wait a few seconds prior to shutting the power off. This is not damaging anything.
    My DT25 also has a hum. There are a lot of reasons that could cause the hum. Does it change with the voicing(digital preamp model)? I note you attempted different power amp settings. On mine the models had varying hiss depending on the model used. Line6 simulated the hiss and spit of the preams the mimiced. Voicing 3 seems to be the quietest for me. Setting mine into triode mode produces a low hum vs a higher hiss with the pentode. Is the hum master volume sensitive? If so the issue resides in the preamp. If not look to the power amp side. The DT25 is very picky about constant noise free power so borrow a power conditioner if you can and see if that helps. My mods to reduce hiss were replace the stock tubes with MESA tubes and rebias. I also bought a Furman M-8 line conditioner(eliminated random crackles and pops). Some hiss/hum is normal in tube amps. I tested the DT25 side by side with a MESA TA-15 using the same speaker cab in a isolation room at Guitar Center. I found that the hiss was comparable for similar topologies. I did note that the TA-15 sounded subtly brighter and more punchy due to pure analog path but, cost and lack of channel switching killed it for me.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
