276 Views 3 Replies Latest reply: Jan 12, 2013 7:09 PM by Krontab RSS
iwarbride Just Startin' 2 posts since
Feb 17, 2011
Jan 9, 2013 8:46 AM
using the POD HD 500 with other pedals...HELP
hey everyone,  here is my current rig,
GLP Studio
Boss TU-2 Tuner
Vox Satchrator
Boss Flanger
POD HD 500
My question,
Im mainly using the HD 500 (signal chain - Noise gate, Parametric EQ, Line 6 Epic Pre amp w/cab & mic , Digital Delay, Ducking Reverb.)  for my rhythm tone.  i want to set up the satchurator for my lead tone..  is there any specific way i should run my complete chain?
guitar - tuner - Satchurator - HD500 - (BOSS Flange in the effects Loop) to my PA/AMP?   OR should i run in a different pattern....
thsnks guys...
Josh
  • geoff_p Just Startin' 4 posts since
    May 16, 2009
    Jan 9, 2013 2:19 PM (in response to iwarbride)
    Re: using the POD HD 500 with other pedals...HELP
    I'd stick the dirt box in the loop before (or after to taste) the flanger in the loop, keep the loop on all the time so i can turn on flanger and/or dirt as wanted. or then again i'd stick the flanger between the pod and the power amp rather than in the loop so it is after preamp. or stick the dirt before the pod and the flanger in the loop after the preamp. what fun! is it just me or are the pods flangers vey limited?
      • Krontab Just Startin' 201 posts since
        Mar 15, 2006
        Jan 12, 2013 7:09 PM (in response to iwarbride)
        I have a Flex III XL and it has an external speaker plug on the back. Not sure if the Flex II had that. As for modding there is just a positive and negative wire going to the speaker that could be spliced into. Reguard Ohms law if running parrallel wiring. Do not go under the minimum ohm rating or you will overheat and damage the amp.
