142 Views 5 Replies Latest reply: Jan 10, 2013 7:38 PM by Carbibbles RSS
Carbibbles Just Startin' 3 posts since
Jan 9, 2013
Jan 9, 2013 8:52 PM
valve mkii sound
Hello, first time line6 owner here. I had originally bought a floor model valve mkii 112 from GC and it sounded amazing at low volume, but once you cranked the volume it sounded like a blown speaker. So I took it back and they exchanged it for a new one. The new one sounds decent at high volume but at low volume the distortion isnt quite the same, its a bit fuzzy and scratchy and whereas before you could make the amp scream with ease, now you really have to work the guitar to make it scream. Do these amps need to be broken in or anything? I heard about a difference between firmwares but my new one is v1.20 and I cant recall what the original amp's version was but I would assume it was also v1.20.
Thanks
Jason
  • esibanjack Just Startin' 35 posts since
    Mar 30, 2012
    Jan 10, 2013 10:15 AM (in response to Carbibbles)
    Re: valve mkii sound
    If your first amp was a floor model it's possible that it was a return that had been updated to firmware 1.50 or 2.0, although if that was the case, your experience would contradict what many others have stated previously on this board. If you were to go back into the history of this forum you would find that most people think the SV MKII amps sound better at lower volumes with the original firmware than they do after an update to version 1.50 or 2.0. Even Line6 says the amp models were changed in the later firmware versions to sound better at higher volumes. It's also possible that your original amp settings had been "dialed-in" a little bit while it was on the floor, which could account for some of the tone difference. At the end of the day, tone is a subjective thing, so my recommendation would be to update to 2.0 and see how it sounds, as you can always roll-back to the original firmware if you're not happy with the results.
        Mar 30, 2012
        Jan 10, 2013 4:17 PM (in response to Carbibbles)
        I have the HD100 MKII, so I don't have any experience with the combos. I know from reading the forum that many users don't turn their channel volumes up much at all, but I believe this was really more to avoid an annoying "POP" when they would switch presets. I have found that the presence knob can affect the tone quite a bit, so that's where I would start. Unfortunately, this forum has been pretty dead for quite some time, so I don't know how many more responses you're going to get. You would probably be better off taking some time to read through some of the old post, as there is a wealth of info on here. I would start at the present day and then work my way back to when the MKII's were first rolled-out, which I believe was around October of 2009 (forum page 85 perhaps?).
      • spaceatl Expert Line 6 User 4,456 posts since
        Jan 24, 2007
        Jan 10, 2013 6:07 PM (in response to Carbibbles)
        The bias could be low? You seem to be describing a "cold" tone...like the amp sounds cold...W
        hen bias is high on a class AB tube amp like the SV, the power amp amp turns more class A with less B component...anyway, it generally means a warmer tone...But at the cost of lower damping...Basically, it can get spongy and kinda messy at higher volumes because the amp is running with way less headroom...think if bias like a car idle...if the idle is high, then your engine is closer to the redline...
        Anyway, you can check the bias with a multimeter...but if you are not comfortable with high voltages, have a pro do it...This amp has 400v plate voltage...it can be lethal...
