137 Views 7 Replies Latest reply: Jan 10, 2013 9:30 PM by ivylotus RSS
ivylotus Just Startin' 27 posts since
Jan 7, 2013
Jan 9, 2013 9:41 PM
Volume levels between models?
I'm curious: Is the big volume differences between different amp models on the DT25 intentional? Seems like going from a AC15 to a Twin makes things get much quieter. It's not a huge deal, but I don't understand why it happens.
Thanks,
Matt
  • greghall Just Startin' 160 posts since
    Feb 2, 2007
    Jan 10, 2013 1:38 AM (in response to ivylotus)
    Re: Volume levels between models?
    The difference in volume between the amp topologies is due mainly to the analogue components in the amp, rather the pre-amp modeling itself, i.e. the NFL, class and mode. Each of these affects how the power / signal is put through the tubes, and therefore the output volume. Obviously the pre-amp gain is also a factor.
    It makes sense if you think of this as 4 (or more) different amps in one box, rather than a single amp with different channels.
    Hope that helps.
      • spaceatl Expert Line 6 User 4,456 posts since
        Jan 24, 2007
        Jan 10, 2013 1:59 PM (in response to ivylotus)
        Twins don't have a Drive knob in reality...So in the HD model one approach is to dime the channel volume and use the drive as the volume...That's a little more reflective of how a real twin migh be used...
        DrZ, the bass control is actually a second gain...At least if my dimentia isn't getting the better of me...
            Jan 24, 2007
            Jan 10, 2013 9:10 PM (in response to ivylotus)
            Yes, it is documented indirectly for DT only users...Keep in mind that this ability of the DT amps actually having all the amp models in them is a fairly recent thing...At the core of the DT design is the intention to use an HD POD to control it via the system link...So this midi control might not be as high a priority...just a guess...but I am very glad they disclosed that the amps could do this...
            control changes display in the interface of an HD POD...Check out section 6-13 in the HD500 advanced manual...There is also the Model Gallery manual that that gives some good background on the actual amps they modeled with photos...That might help get uder it a bit...Would be a nice feature add for that excellent editor a user came up with...
            The DT preamp is an HD modeler...albiet, special purpose in terms of there only being reverb for FX...The HD 500 POD manual are probably a good place to get more insight to the HD amp, cab and mic and reverb models you have in your DT and the options you have...
    Dec 22, 2006
    Jan 10, 2013 5:22 AM (in response to ivylotus)
    gregs right on... the internals of the amp, and the characteristics of the original amp being modeled are such...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
