Jan 12, 2013 7:49 PM
Cut out on one patch but not other(s)
Like (0)
I will preface this with the fact that I need to do some more troubleshooting but wanted to see if anyone has had this happen.
Last night at rehearsal I was using same preset most of the night on my PODHD500 into my DT25 via iLink. Towards the end (approx. 2 hrs in)...I switched to another preset and noticed some intermittent volume cut outs. Went back to other preset...no cut outs..repeated and just the one preset would cut out - which it's never done before.
One item of note: First preset was on Topology 3...Preset that cut out was #4.
thoughts and input welcome
thanks,
Todd
I've had wierd things happen when I'm patch switching in HDedit. I just have to reboot the POD to fix the issue. I have not had your specific issue. In the topology switch did class or mode change? Typically voicing 3 is run Class A and 4 is run Class A/B. Class A is not effected by tube bias where Class A/B is. Maybe the tubes are going or the bias needs to be reset.
