225 Views 20 Replies Latest reply: Jan 14, 2013 11:43 AM by hurghanico RSS
chico11 Just Startin' 17 posts since
May 16, 2009
Jan 13, 2013 8:57 AM
HD500 connection
Hi I just got a Line 6 Pod HD500 I have it connected
To my line 6 UX8 through the unbalanced
1/4 left out of HD500 into my instrument
1Input on the UX8 into sonar x2 but in sonar
I cannot adjust my guitar level in my track
The sound from my guitar is always constant
Even if I lower my level all the way in sonar
Could somone help?
Thank you....
  • hurghanico Just Startin' 399 posts since
    Jan 28, 2007
    Jan 13, 2013 9:58 AM (in response to chico11)
    Re: HD500 connection
    are you sure the selected audio card for your track recording is UX8?
    if not, maybe it is set instead on HD500, in wich case the master volume knob position of your POD will be irrelevant (just for monitoring purposes)..
    the signal going through USB is digital and you can control its level with the "Line 6 Audio-MIDI Devices" driver application.. you can find it in your start menu..
    (clik on the pic to zoom-in)
    just adjust the "Record Send Level"
    otherwise be sure to select UX8 as the source for your recording track, and in this case use the POD master volume knob to set the right level
      Jan 28, 2007
      Jan 13, 2013 2:00 PM (in response to chico11)
      chico11 ha scritto:
      ...Is there a way to connect the pod hd500 to be able
      To adjust level  and pan in my sonar track why'll
      Someone els is playing?...
      I think that in Sonar the monitoring level and pan setting of a track can be changed while it's recorded or when is in playback regardless of the way the POD is connected, and maybe those parameters changes can also be recorded at the same time as an automation.. but for that topic you have to ask in the Cakewalk forum, or study the Sonar manual..
      if you can't change the monitored track volume and pan setting maybe you have to toggle some Sonar switch, let say: track monitoring on or off.. I don't know.. I use Cubase
      regarding the HD500 you can connect it only in 3 ways: digitally through USB or S/PDIF, or through the analog inputs of an audio card, that's it, no special tricks..
      I think your issue depends only on Sonar track settings
      Jan 28, 2007
      Jan 13, 2013 3:01 PM (in response to chico11)
      chico11 ha scritto:
      ...I noted too that if I turn of my computer
      And play I still get sound from my monitors???
      Is that normal??...
      maybe yes if your monitors are connected to the UX8 still on..
      Jan 28, 2007
      Jan 13, 2013 5:09 PM (in response to chico11)
      you're telling me that by connecting a guitar alone or with the pod at the same UX8 input, the track volume works only when is connected just the guitar?? ..
      does not make any sense!
      Are you kidding me?
      Jan 28, 2007
      Jan 13, 2013 6:12 PM (in response to chico11)
      the only logic explanation is that the UX8 input where you connect your POD is directly monitored out bypassing Sonar, and the UX8 input where you connect just the guitar is not directly monitored..
      if instead in your experiment above the UX8 physical input used for the connections is the same for both the guitar alone and with the POD in between, as i said before: does not make any sense that the Sonar track volume influences only the guitar (alone) level, and not with the POD in between...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
