95 Views 1 Reply Latest reply: Jan 16, 2013 7:42 PM by dboomer RSS
Dougyfish Just Startin' 1 posts since
Jan 15, 2013
Jan 15, 2013 4:46 PM
Getting sound to a StageSource Speaker - Alternatives
Last year I purchased a Mackie DL1608 and really like it.  But I see the advantage of the MOD20 system with the StageSource speakers.  So I'm thinking forward to building a complete system.  I'd like to be able to use what I have while I build the system over time.  So my question is, what would be the best way to get audio from a DL1608 to a StageSource speaker wirelessly?
Thanks,
Doug
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    If you want the sound to be as good as it can be then any of the Relay or XDV systems would work great.  Just depends on the number of channels you want to use and the distances you need to hit.
    Just plug the line outputs from any mixer into the beltpack transmitters and plug the output of the receivers into a mic level input on the speaker systems.  You may need to add 15 dB pads to the outputs of the mixer to keep it from overdriving the  inputs of the transmitters (although they will handle about 6 volts peak ac at their inputs).
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
