236 Views 3 Replies Latest reply: Jan 21, 2013 6:17 AM by phil_m RSS
danieldanza Just Startin' 2 posts since
Nov 17, 2010
Jan 18, 2013 1:56 PM
M9 expression pedal issues
So I recently purchased an Ex-1 for use with my M9.  I had previously used an Ernie Ball volume pedal jr which worked for about 20 minutes.  The EX-1 does not work regardless of input/cables used or how it is set in "setup.". Since this has now happened with two pedals I'm beginning to think its an issue with the M9 it's self...
Now, I know there is a past discussion on this forum on a very similar topic but I remain somewhat skeptical that taking the M9 in for service is my only option.  This might be wishful thinking since I don't have much money to pay for repairs.  Nevertheless I want to exhaust all other options before I bring it to a pro.  Any advice would be appreciated....  Is there a particular way to set up the expression pedal in the universal settings?  Why did the Ernie ball pedal work for a bit then fail?  And how come neither input works?  Seems peculiar.
Thanks,
-D
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Jan 18, 2013 4:17 PM (in response to danieldanza)
    Re: M9 expression pedal issues
    There's not universal settings for the expression pedals, but the way they work in whatever scene you're in depends on how you have them set up in that scene. The process of setting them up is described on Page 2.2 of the Advanced Guide. So you have to decide what effect engines are controlled by what expression pedal. I suspect that might be the reason you're Ernie Ball pedal quit working. Perhaps you went to a scene where the pedal wasn't setup to control anything.
    • pianofiend80 Just Startin' 1 posts since
      Jan 21, 2013
      Jan 21, 2013 5:44 AM (in response to phil_m)
      I've had my M9 for about a week and have already run into issues when using the expression pedal, an M-Gear EX-P (made by M-Audio.) As others have mentioned in other posts, the pedal seems to quickly "forget" the heel and toe parameters I've set for certain sounds, particularly 'Pitch Glide' and any wah pedal effect. With a wah effect it might work fine for half a minute (or 5 seconds) and then the POS parameter freezes at 100%, leaving the pedal inoperable and your tone in no-mans-land. The moment when it forgets seems to come at random, not based on my foot movements on the pedal. This rig was all sitting on the shelf in a music store only 7 days ago, so I'm way less than impressed at having run into problems at this early stage. Any pearls of wisdom that I might not find by sifting through every relevant post and response on the site? The pedal is a pretty cheap and nasty one, but it seems like people are having similar issues with pedals of twice the price.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
