46 Views 1 Reply Latest reply: Jan 20, 2013 12:37 PM by DickFoster RSS
Lemec Just Startin' 3 posts since
Sep 10, 2010
Jan 19, 2013 11:21 AM
[HELP] Variax thru VDI not locking
I own a Variax 300 guitar updated to the 3.10 firmware and a Vetta II fully update too. When i plug the Variax in front of the amp with the due switch (to give power to the gtr) i get all the functionalities...But...When i try to connect the Variax to the Vetta II thru the Line 6 CAT5 cable to the VDI of the head, Vetta does not lock on the Variax changing from ON to N/A back and forward. I've set the patch according to the manual and still the problem remains. HELP ...
I've checked the out (CAT5) of the Variax plugin it into a floor POD Xt and it worked fine.
  • DickFoster Just Startin' 98 posts since
    Jan 26, 2012
    Jan 20, 2013 12:37 PM (in response to Lemec)
    Re: [HELP] Variax thru VDI not locking
    I thought the Ethernet jack was just for floorboards/pedals and the optional digital interface that came standard on the Vetta IIs was for the Variax guitar interface. Are you sure you're connecting to the right spigots on your amp? If you have an original Vetta I you used to be able to upgrade it to have the digital interface but no more as Line6 no longer supports or supplies it. ARe you plugging into this one, labeled VARIAX IN?
    http://www.vettaville.com/photos/vdi-connections1.jpg
