5 Views 1 Reply Latest reply: Jan 25, 2013 7:31 PM by paylor1970 RSS
Line6Customtone Just Startin' 1,140 posts since
Mar 11, 2009
(212628) MakeItRain by ricksox
For this tone I wanted something a little unusual. It may not be a sound many of you can use regularly but I think it could make for a good effect in a small part of a song…maybe an intro for example. The trick to this tone is to hang out on the high E and the B strings. Experiment with letting notes sustain around the 12th fret. The effect should sound sparkly and a bit wobbly due to the Wow/FLT being set so high. I find that letting the notes sustain for as long as possible really make this tone shine. I’m using the PhD Motorway amp model based on* the DrZ® Route 66 amp. The Drive is set fairly high to 67% but you can tweak to taste. I’ve got the Time parameter on the Tube Echo delay model set to 260ms. The Feedback is up pretty high at 75%. I really crank the Wow/FLT parameter on this patch for that extra “wobble”. It’s set to 65%. Drive is set to 0% and Mix is way up at 75%. Have fun with this one.
