98 Views 5 Replies Latest reply: Feb 1, 2013 4:18 AM by RonMarton RSS
Kilpo Just Startin' 3 posts since
Jan 30, 2013
Jan 30, 2013 12:24 AM
Which Rode Micon connector for Line 6 XD-V75?
I just ordered a XD-V75TR for use with a Rode Pinmic. The salesman tells me I need the Micon3 connector, but I am unable to find any supporting documentation for that recommendation. Does anyone know if the Micon3 is the correct connector?
  • RonMarton Iknowathingortwo 357 posts since
    Jan 12, 2012
    Jan 30, 2013 1:56 AM (in response to Kilpo)
    Re: Which Rode Micon connector for Line 6 XD-V75?
    Rode's Micon 3 does physically fit, Kilpo...
    And the pinouts are correct for signal "hot", signal "cold", level, impedance and DC power,
    ...HOWEVER...
    1. I'm not aware of successful implementations of Rode's PinMic with V70 or V75 beltpacks and
    2. I've also seen nothing to suggest that you'll be able to avoid experimentation along the lines undertaken by others who did (eventually) achieve successful operation of Rode's HS-1 headsets with their V70 beltpacks.
    The history of that process is covered in this discussion: http://line6.com/support/thread/60468?tstart=0
    I'd also add that me being Australian didn't stop me from "giving up" on Rode's PinMics, in spite of their very fine sound when connected to the Sennheiser beltpacks that I was then using for TV series production.
    All of us ended up being heartily sick of "pin stick" injuries, so we ended up returning to more common "standard" lavalier mics and (where necessary) concealing them under clothes with "body tape", ...using this magic little "rustle-stopper" (available in beige or black) from Sanken: http://www.bhphotovideo.com/c/product/745486-REG/Sanken_RM11SINGLE_BLACK_Rubber_Microphone_Mount_Black.html
        Jan 12, 2012
        Jan 31, 2013 3:21 PM (in response to Kilpo)
        Well, Scott,
        Rode's PinMic is undoubtedly a beautiful-sounding (albeit rather expensive) lavalier, and as you're only fitting it to one person, (unlike our need to constantly re-attach for costume changes) the "pin-stick into finger" problems that we suffered may well not occur, ...especially not now that you're forewarned.
        There are, however, two other critical issues that apply to your intended use:
        1. Gain. As I mentioned earlier, I'm unaware of anyone having reported the levels that a PinMic actually feeds into a V70/V75 beltpack and
        2. Feedback. Like the majority of lavaliers, the PinMic is omnidirectional, meaning it picks up sounds from all around.
        That second point may well give you a lot of grief, as the chest location of such a lavalier requires much more gain than the "next to the corner of the mouth" position that allows the successful use of (seemingly similar) omnidirectional headset mics with PA systems such as yours.
        Like all radiation, (such as light) sound follows the "inverse square law", whereby halving the distance doesn't merely double the gain, it yields four times as much, (the square of two) with a third the distance yielding nine times as much !
        So my suggestion would be that you hold off on investing in a PinMic until after your wife has experienced for herself the amazing comfort and unobtrusive excellence of the mic that I'd recommend for your pastor, ...one of these:
        http://www.amazon.com/Samson-SE50-Headset-Microphone-Beige/dp/B002BO53LO/ref=sr_1_1?ie=UTF8&qid=1359669301&sr=8-1&keywords=Samson+SE50
        (Also available from other reputable audio suppliers such as http://www.sweetwater.com/store/detail/SE50tan/  or http://www.bhphotovideo.com/c/product/586049-REG/Samson_SASE50T_SE50_Headworn_Condenser_Microphone.html )
        I own a dozen of them for my eight XD-V beltpacks, four configured with large windshields for exclusive use by rugby referees, with the remaining eight being used for exactly your type of vocal (PA) work. (Feel free to click on my pink avatar at left for details of my location rig.)
        (A little "tip": a tiny dab of clear silicone "goo", the type used for sealing leaks in tiling and shower recesses, carefully applied from a pin's head to the side of the SE50's mic body is a great way to avoid the mid-sermon loss of its foam "pop-stopper" windshield, even though Samson, uniquely, include several spares ...and their replacement parts are cheap.
        That "goo" is then easily "rubbed off" and re-applied when replacement is eventually needed.)
        I'm confident that, once tried, the Samson SE50 will become an indispensible part of your spreading The Word via Line 6's brilliant beltpacks.
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
