149 Views 9 Replies Latest reply: Feb 2, 2013 12:46 PM by amx05462 RSS
codamedia Just Startin' 14 posts since
Nov 30, 2011
Feb 2, 2013 7:55 AM
Variax 300 VDI Port Died suddenly
The VDI port on my Variax 300 seems to have completely quit on me. I've been using it without issues up until last evening when I fired up my studio and the guitar was not connecting to my X3 Live.
  • I own two X3 Lives, one for live and one for studio. The VDI connection from the guitar is not working with either X3.
  • Monkey and Workbench cannot see the Variax through the X3 Live devices, although Monkey and Gearbox can see both X3 live devices.
  • I have tried a Line 6 VDI Cable, and 3 standard cat 5 ethernet cables (I usually use the VDI cable live, and the ethernet cables at home or in the studio). All cables I tried have worked in the past.
Based on the above attempts, I have ruled out a problem with cables and my X3 Live ports. Leading me back to the Variax.
  • Using AAA Batteries, the guitar works fine
  • Using the XPS-Mini and the Line 6 TRS Cable also works fine.
Based on that - I believe I have a problem with the VDI port on the guitar itself. Although the guitar works fine with batteries or the XPS-Mini, I really want the VDI to work.
I use VDI in live performances to change patches on the guitar automatically via the X3 but more than that - I am uncomfortable that I cannot backup/restore and/or edit any patches on the guitar.
If anyone has any suggestions for troubleshooting I have not tried yet - I am open to suggestions.
EDIT TO ADD: A while back I forgot the power supply for my X3 Live at a practice. I loaded the guitar with AAA batteries and went direct to an amp, but I never removed the battery pack when I went back to the VDI connection. I have read on these forums that you should not have batteries installed when using the VDI or XPS. Those batteries still work fine now, but could this be a source of my problem? For the record, I did remove the battery pack when doing all the tests listed above (except when I tested the battery pack of course).
  • amx05462 Power User 3,495 posts since
    Sep 1, 2008
    Feb 2, 2013 8:18 AM (in response to codamedia)
    Re: Variax 300 VDI Port Died suddenly
    you have eliminated the  guitar having a problem by  both cases  where it  does  work fine  by what you said.  id  say its  the power   connection from your pedal.  look in that connector  for  one of the  connector  wires  to be lower than the rest.   if so your not getting power  from your pedal. theres a couple of fixes  for that   on here.
        Sep 1, 2008
        Feb 2, 2013 9:45 AM (in response to codamedia)
        when  you said  it  works fine  on batteries  and also with the  xps mini  and   its cables   i thought  you meant  you were  sending  sound  through  that to your computer  or amp  or pedal.   what im getting    now  is that   its  just powered  through  either  batteries   or the xps. power  supply. in which case   then it could be at the guitar .  if  your saying  you get sound from  the  1/4  output  but not the  xps   then it could be the  guitar connection.     but  i based   my conclusion  on whatyou originally said.  either  way  the compressed   connector   on either  the  guitar  or  on the  pedal  seems  to have been a common problem a few  years  back. so  id  look into all those connectors.  . all it  ever  was     was  one  wire  that was  stuck  low  and didnt  connect.  id  check every  one  that you  have   .. just to be   sure.
            Sep 1, 2008
            Feb 2, 2013 11:11 AM (in response to codamedia)
            well if  you have verified  all connections  with a meter..   and  they all verify from the  main board  to the  other  end  of the plugged  in  vdi cable....  its not the vdi socket at all.  if you cant  go from the  socket to  the other  end  of the plugged  in cable  then its  the socket. if you can go from the main board connector  to  the outer  end  of the plugged  in  cable  its  not the  socket  so from that pount  you have to look at the  connections  on the main board   possibly a resistor.  i recall  someone  with a burnt  resistor  at one time..  i believe  that  had  to get sent  out  to the company..    but thats  what id do next . unplug  the vdi connection to the main board  and  check from that connector to the  other  end of the plugged  in vdi cable
                Sep 1, 2008
                Feb 2, 2013 12:46 PM (in response to codamedia)
                well best of luck with it. btw  while your in there  you  might  want to  insulate that coffin case  from the main board   alot  of people  had problems  in that area  as well. you can  either  get some  of that liquid  electrical tape  and  paint the inside  with that or  just spray it with a couple of coats  of nonconductive paint.   i dont  think this is  part of your problem  but again while your in there  why not  kill two birds  with one stone.. theres a bunch of past posts  on that issue    on this  site..  you might find them under  the dreaded  coffin case  problem or something  like that as i recall.
