377 Views 11 Replies Latest reply: Feb 14, 2013 2:11 PM by toasterdude RSS
Nipp Just Startin' 50 posts since
May 21, 2012
Feb 3, 2013 4:58 AM
Is JTV sensitive to different string guages?
Hi
Reading about how Variax system seem to work with taking part signal from piezos and emulations, and some people also get different sympathetic resonance issues with different tunings - I wonder about this.
Saw the video from NAMM and 89F demonstration, he said it was delivered with 010-set, but he was about to put 011 set on it.
011's and 25.5" scale length, that's heavy duty.
Any notes from Line6 in manual on string guages or brands at all?
Thinking that different strings have different properties and produce harmonics that Variax is not tested with.
And locking nut and bridge saddles, can you do anything to these to fit other guages of strings?
The FR bridge saddles, how about them - any limitations?
And finally - are the nut and bridges shipped with 89F standard that can be bought elsewhere for replacement?
Thanks.
Best regards
  • Krontab Just Startin' 201 posts since
    Mar 15, 2006
    Feb 3, 2013 5:54 AM (in response to Nipp)
    Re: Is JTV sensitive to different string guages?
    I experimented with this a bit. What I discovered is that 9's didn't work as well due to the piezos. Essentially you can equalize magnetic pickup sensitivity by adjusting proximity, but since the piezo are not adjustable, string mass matters. I found that 10's or 11's had little variance from each other but were far superior to the 9's and made the accoustic models sound better. Another thing I found different is that slight string buzz that magnetic pickups ignore is present in piezos so I had to set the action to absolutly no buzz. I found that higher guage strings allowed for a lower action without buzz. Hope this helps.
          Mar 15, 2006
          Feb 3, 2013 11:30 AM (in response to Nipp)
          I tried compensating with the workbench. Sustain did improve but the general noise floor was higher. I also found with anything less than 10 gauge the the truss rod was almost at a slack tension and the tuning became more temperature sensitive. I guess it makes sense to me, as it really is accoustic pickup system that has been co-opted as a reference singnal to filter to create a desired model, that it would function better with higher guage strings.
              Mar 15, 2006
              Feb 3, 2013 8:50 PM (in response to Nipp)
              I have the 59.
              No official statement I'm aware of other than that they come stock with 10 gauge. I'm assuming that 10 gauge is the referance used for the models.
              Material does matter. I used pure nickel DR strings and they  did not have the same as they have on magnetic pickups. They made the low end muddy through the piezos. I ended up using regular slinky's. I was able to get a 2 32nd inch action at the 12th fret on the high side and 3 32nd on the bass side (factory spec from Gibson for a 1959 Les Paul) with no buzz.
  • Thumpingrug Just Startin' 40 posts since
    Oct 29, 2008
    Feb 4, 2013 12:25 AM (in response to Nipp)
    I changed my 69 to a set of 9's from the stock 10's it came with.  Absolutely no difference in sound output what soever.
        Mar 15, 2006
        Feb 4, 2013 4:48 PM (in response to Nipp)
        I would also expect that the 69 physical construction differences from the 59 to effect sustain more than the string gauge. Bolt on necks and floating bridges are typically less energy efficient. Heavy tone blocks help this a bit. I would say in my experiments the tonal differences between electric models is really subtle but the accoustic models sounded less punchy.
  • toasterdude Just Startin' 745 posts since
    Oct 23, 2006
    Feb 14, 2013 2:11 PM (in response to Nipp)
    I use 11s on all my JTVs. All my JTVs are 25.5 inch scale or will be once all transplants are done. To me they sound better than the 10s but I just prefer 11s on any guitar, not variax specific. No negative effects that I can detect.
