Feb 7, 2013 7:41 AM
Pod HD has very limited custom tone presets
Like (0)
In other POD products, there are tones for spesific songs, variety of bands... But in podhd there is not, if line 6 comes up with an update which you can download every tone you want, not only podhd's, it would be great.
Pod HD Desktop tones are compatible with Pod HD500 and HD Pro tone files. You can usually load HD500/Pro tone files into Pod HD Edit by renaming the files. In most cases you will have to edit the Inputs because the HD has fewer inputs than the 500/Pro. There is also a patch conversion utility that will handle the inputs for you if necessary.
Thank you first of all, do you have the link of the patch you talked about?
thank you very much
