21 Views 0 Replies Latest reply: Feb 14, 2013 8:58 AM by tobislaf RSS
tobislaf Just Startin' 1 posts since
Dec 20, 2010
Humming noise from output jacks (and input jacks); Toneport UX8
Hello folks,
i  tried to reamp something with the UX8 which seems to fail already at its output jacks (even the input jacks).
I allready searched on google for about two hours with no compareable result. So here goes my Problem:
No matter how i configure the chain of gear or route the signal to the outputs, the output jacks (or input jacks) add an unbearable ammount of a humming noise to the signal ( I dont have to play something through the output, connecting one of them to my amp or effect-pedal already creates the noise).
The only thing that doesn't seem to be affected by the noise is a mono headphone which came with an old metronome and which i plugged in the outputs for the purpose of testing.
I even tried connecting the toneport-input to the amp-input -> same result: horrible noise comes from the amp.
So naturally i would go with a grounding issue; but i belive i rouled that out by adding the ground connector of my pc to the jacks / to the case -> no change.
I also assume the cables to be fine since i never had any problem with them and tried 3 diffrent cables.
Chain of Gear:
Toneport-output -> Amp-input  >>>[UNBEARABLE NOISE]>>>    (-> sm57 ->toneport-XLRinput)
OR
Toneport_output ->podhd500_4cable-method -> Amp >>>[UNBEARABLE NOISE]>>>    (-> sm57 ->toneport-XLRinput)
What could it be? And how can i resolve it?
Greetings and thanks upfront,
Tobislaf
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
