69 Views 2 Replies Latest reply: Feb 17, 2013 2:40 AM by indigobjn RSS
indigobjn Just Startin' 98 posts since
Sep 19, 2011
Feb 14, 2013 10:59 PM
POD HD400 Mode Footswitch problem
I have a problem with MODE Foot switch. The problem is that 50% of time when I presss MODE FS it toggles rapidly between PRESET MODE, LOOPER mode and STOMP mode. For example. If I press MODE FS once when I'm current at PRESET MODE, instead of going to LOOPER mode either it goes to STOMP MODE (goes to LOOPER mode but instantly goes to STOMP MODE) or goes to PRESET MODE itself after instantly going through LOOPER and STOMP mode. Is this happening due to poor electrical contact? Any one?
- indigobjn
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Feb 15, 2013 12:18 PM (in response to indigobjn)
    Re: POD HD400 Mode Footswitch problem
    If you don't use the looper much, there is a setting for it in the system menu....Hold4Looper....If you turn that on, then the Mode should toggle between STOMP and PRESET....hold MODE for 4 sec or so for the LOOPER...not sure if that would help, sounds like you might have a funky button that needs to be cleaned or replaced...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
